Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Makin progress
Old 09-25-2015, 09:06 AM
  #241
Naf
Naf's Avatar
Default Makin progress
I saw how the rear spreads when i hit it, so i designed it in a way that keeps both sides inline and centered. So they move together and stay in their locations. Hopefully i dont rip them m10 bolts out of their locations...
Old 09-25-2015, 11:59 AM
  #242
CTS-V Shifter Sales
07CTS-V's Avatar
Originally Posted by Naf
My original harness had a few connection issues. I couldnt get it fixed locally and i couldnt get a guy in the states to make me a new one in milspec wiring. Rywire just wasted my time and and money in shippin...
I toyed with the idea of swappin the harness a few yrs ago, but didnt understand why it didnt work.
So this time around i researched it and found i needed to do a few upgrades to the harnesses to get them to work.
Additionally the e67 ecu is superior to the pcm for better ignition timin, faster processor speed, better traction control, and better fuel injection control
I am so close to finishin its not funny any more the new harness works minus cruise control.
....and waaaay worse for tuning anything over 500 rwhp or boost. Scale the entire tune instead of upgrading the OS.
Old 09-25-2015, 12:33 PM
  #243
Naf
Naf's Avatar
What makes you say that?
The e67 ecu is used on zr1, v8 trailblazers, and i have read great reviews about this ecu...
Old 09-25-2015, 01:27 PM
  #244
CTS-V Shifter Sales
07CTS-V's Avatar
Possibly different for EFILive, but HpTuners hasn't supported the E67 for the CTS-V with upgraded operating systems to expand the parameters. Many items have max values that are way less than higher Hp cars require. Example, you have to scale the tune by 48% to fit all the values from ID1000's into the IFR table, max MAF numbers support only 550 rwHp max...
Old 09-25-2015, 01:48 PM
  #245
Sssnake's Avatar
^ What he said. There are lots of little drivability things as well. Integration delay for the O2s is my pet peeve. Also, things like positive timing adjustments in the IAT timing table not working but negative working fine... Because very few people run this OS finding someone that really knows what is going on is nearly impossible.
Old 09-25-2015, 01:53 PM
  #246
Sssnake's Avatar
The hardware is good make no mistake. However, take a look at the pinouts for these e67 ecus. They're different. I assume these ECUs are using FPGAs and GM is not requiring a standard wiring interface. Therefore, you can't just blast in a new OS and have the benefits of the ZR1 or trailblazer OS. You would have to do a harness swap to pull it off. I have seriously considered buying a CTS V2 ECU and harness and swapping it into my V1. A LOT of my current issues would disappear (a few new ones would likely pop up). Bottom line is the OS on the V1s sux.
Old 09-25-2015, 10:52 PM
  #247
Naf
Naf's Avatar
The zr1 is canbus and so is the new v2 ctsvs 100% but the trailblazer until recently is still class 2 which we need.
Old 09-26-2015, 08:44 AM
  #248
Naf
Naf's Avatar
Btw isnt the pcm limited to the same maf restrictions as the e67?
512g/s
But the ve is easier to adjust vs the virtual ve on the e67
Old 09-26-2015, 10:31 AM
  #249
Junior-1's Avatar
I've got no experience tuning aside from loading and unloading tunes, but seeing as much money as we have spent on these things, how come you never looked into just a Bosch motorsports ecu and abs setup? It probably would open up unlimited possibilities...
Old 09-26-2015, 12:10 PM
  #250
Naf
Naf's Avatar
Need more of a plug and play...
Ur sayin ya rite plug and play
But it works with everything else...
I will talk with jason at lpe there has to be os upgrades to give more power for me than 550rwhp/rwtqlb
Old 10-04-2015, 12:11 PM
  #251
Naf
Naf's Avatar
So i was putting everything together on the rear end and i noticed one of the cv axle nuts was missin
Does anyone have a pn so i may check locally for one and get my beast ready to start and move a little
Old 10-05-2015, 04:43 AM
  #252
Naf
Naf's Avatar
Got the Pn and sent my minions to search the local scene for the nut...Thank you Rockauto
So Latest achievement today was i resolved my oil lines touchin the headers, but what a pita. I ended up swappin the hoses, using hose clamps and flippin the output so clearance is now plenty, bleed the system just to remove it again and install another 90 elbow on the output so the hose flows easier with longevity in mind. My friend hates me today, but i got him a nice lunch so he calmed down a little...
I installed the rear tires and in the "race configuration, the coilover touches the wheels. *sigh*
I am making new shock bottoms pullin the shock inwards 10mm, which should give me the clearance i need...
I am also goin to install my new innovate dual WB sensors so i may have control of both banks and not just one. I calibrated the outputs so 14.7=450mv
Once i close up these little tasks i will start her and try and find any new issues.
Old 10-05-2015, 08:42 AM
  #253
NIKDSC5's Avatar
pictures of the coil overs hitting the wheel?
Old 10-05-2015, 11:42 AM
  #254
Naf
Naf's Avatar
Ok, tomorro you shall get your pics...
My oem clutch master cyl called it quits, thankfully i have a upgraded replacement...
Tomorro should be a good day
Old 10-06-2015, 01:37 AM
  #255
Naf
Naf's Avatar
The dark pic is the one with the shock still attached to the rear knuckle. The nice clear shot has the shock disconnected... But you get the idea.
Attached Thumbnails Makin progress-photo339.jpg   Makin progress-photo198.jpg   Makin progress-photo998.jpg
Old 10-06-2015, 06:35 AM
  #256
Naf
Naf's Avatar
Progress report
-The axle nut is 2-weeks out $6
-The clutch master cyl is finally in but i have to get a new hose as the oem is too big in dia
-Bled the system only to find out they used the wrong hose..Kept getting dirty and i flushed it three times, EPDM hose is NEEDED not hydraulic hose...
-I had to grind a little off the hose crimp so the headers doesnt touch it.
-New pedal is installed but what a PITA, bruised my finger gettin it in
-Dual wb still not installed
Old 10-07-2015, 07:55 AM
  #257
Naf
Naf's Avatar
So i moved onto gettin the passenger light to fit around the zo6 tank
As you can see i butchered that light and it still wont fit properly...
Tomorro is a new day
Next problem get the plastic shavings out of the housing...
Old 10-07-2015, 11:34 AM
  #258
somethingclever's Avatar
what are you waiting on to start up the new engine?
Old 10-07-2015, 11:46 AM
  #259
Naf
Naf's Avatar
Epdm hose for the clutch res to master cyl...
Just finding hydraulic hoses in my local market...
Old 10-08-2015, 05:10 AM
  #260
Naf
Naf's Avatar
Finally got my headlight apart...
250f for 15 mins in my box oven barely did the job...
Next time i will do 250f for 20mins...
I will need to buy another set of lights as my drivers side looks haggard. Plus i want all black and not grey.
Butyl rubber for reassembly
Quick Reply: Makin progress
