Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Makin progress
Old 05-04-2017, 02:33 AM
  #681
Naf
Naf's Avatar
Old 05-04-2017, 04:49 AM
  #682
FuzzyLog1c's Avatar
LS1Tech 10 Year
Nice! Can we get a rev or two?
Old 05-04-2017, 05:37 AM
  #683
Naf
Naf's Avatar
Not yet, drove it for about 45 mins, ect varied from 81-98c dependin on traffic.
Need to see why that happened. Should be a steady 82-85c.
Also had oil spray on the windshield. Need to find out where it came from
Old 05-04-2017, 08:06 AM
  #684
rjoffe's Avatar
Sounds great, and nice to see if all shiny and clean !
Old 05-04-2017, 09:06 AM
  #685
Naf
Naf's Avatar
Clean meh, engine bay could be cleaner.
Have an oil leak that needs to be found. Oil on the windshield is not good. Passenger side.
Old 05-04-2017, 09:38 AM
  #686
FuzzyLog1c's Avatar
LS1Tech 10 Year
I would say check your oil catch can connections, if you have one.
Old 05-04-2017, 11:18 AM
  #687
Naf
Naf's Avatar
I did, and all dry. Its before the louvers so i need to look around a bit more.
At idle my trim is negative, drivin it all goes 10 plus positive. There is a leak. Just need to find the opening.
Old 05-04-2017, 11:54 AM
  #688
Naf
Naf's Avatar
The internet helps
I routed my breather lines like a wetsump system
Drysump systems dont need to be routed the same way. Rhe scavenger pump is capable of creatin negative pressure in the crank, you just need to create negative pressure in the tank. And thwre is my problem. I am goin to take the source hose off the valley cover and connecr it to the tank. This way my intake manifold creates the vacuum needed in the tank which helps create the vacuum in the tank...
Old 05-09-2017, 09:43 PM
  #689
Naf
Naf's Avatar
Gettin closer to gettin Smoother afr from idle till 3000rpm.
Found i had an overheat issue, temp ranged from 82-90 on the highway, and 91-98c city driving.
Today i turned the heater on full just incase to release any air pockets that might be stuck. Temps did better, but still needs works.
I then tried to park in a new spot and lost one of my exhaust vacuum actuators.
70$ plus 10 day wait, fun stuff...
Old 05-10-2017, 09:59 AM
  #690
Naf
Naf's Avatar
Took my girl for a long cruise, temps are better and shows the rad is workin.
The air leak is really bad, i am showin too much positive trim even after i dropped the ifr 5#.
I am goin to use an old treat of pressurisin the intake tube and spray the engine with soapy water to find this leak...
Old 05-14-2017, 01:19 PM
  #691
Naf
Naf's Avatar
May have found my air leak.
Had my two air connections from oil tank to valve cover was loosely tightened.
A little teflon tape, new orings and plier tight should fix the issue.
But now i have a battery drain that killed my batt in two days. So next check, find the electric bleed and then start and test.
Old 05-15-2017, 04:10 AM
  #692
Naf
Naf's Avatar
Found the electric issue, my 150a engine bay fuse was loose.
Addin two 2mm spacers under the fuse to insure proper connection.
Idles much better
Old 05-21-2017, 10:11 AM
  #693
Naf
Naf's Avatar
Car starts nicely, and runs a tad hot all the time.
I have my mew coolant ready, just need to find a good flush.
I am also fightin a ifr table battle. I am lean if i rev it up but rich runnin. I already adjusted the stomp compensation by 50%.
Old 05-24-2017, 01:32 PM
  #694
Naf
Naf's Avatar
Found the 3.42 helps my rear end grip better from 3000-4000.
Before i was poppin the tires loose, now its much better. Grips, and keeps me planted in my seat.
I need to work more on my tune, i know she has more to give, i am just not tappin into it correctly.
Old 05-25-2017, 08:16 AM
  #695
Naf
Naf's Avatar
Quick screen shoot of my run today.
Strange enough my commanded air fuel ratio never drop below 14.63 even when I got on it . It just stayed there which is kind of odd...
I made some adjustments, hopefully now it will kick in.
3500-5000 she screams till i change gears, then she screams again till i get to about 170kph, then i have to use the brakes to bring my speed down before the cops catch me...
Old 05-30-2017, 07:44 AM
  #696
Naf
Naf's Avatar
Today was hot, 50c is what both my cars told me the ambient temp was.
In the shade my v's ect started up at 40c, then quickly escalated to 82c. Normal drivin less than 80mph my ect held steady around 95c. In slow Traffic it spiked to 105c and held there.
I have to see if my 72 pass oil cooler is causin this hot runnin.
I have a 180f stat and all silicone hoses, so i dont know where this heat is comin from.
I have a hd flush in the rad cleanin the coolin system, and 300km left before i change the engine oil out. And i may swap the 50:50 coolant for 40:60 g13 coolant with a new 180 stat.
Could i modify the oem pump to accept the new style stat? Then i can swap in a 174 instead of a 180, with more flow.
Old 05-30-2017, 02:36 PM
  #697
vroom_vroom's Avatar
Drop down more than that. I just got past this problem. Would spike to 232 here and there running 50:50, 25:75 and it will not go past 205 and it was 102 yesterday. Both in the desert, different rock. Don't underestimate dexcools inability to shed heat.
Old 05-30-2017, 02:57 PM
  #698
jmilz28's Avatar
LS1Tech 10 Year
Dexcool is **** for a number of reasons. You're better off with cheapo green stuff and flush it every year. I use the Prestone premix for "all colors" so far with good results.
Where do you guys get silicone hoses, did you make them or what?
Old 05-30-2017, 09:36 PM
  #699
Naf
Naf's Avatar
I had mine special ordered.
Racebikebitz.co.uk
Talk with bruce, let him know Naf from kuwait sent ya.
Old 05-30-2017, 09:44 PM
  #700
Naf
Naf's Avatar
So i have to get more water into my mix...
Quick Reply: Makin progress
