Who runs a boost-a-pump on a V1?
Based on my quick searching, psychobillycadillac, and punishmentcycle? I could be wrong, I feel like that is what I remember. Not a lot of info on it really (or at least for a V1). If there is please pardon me for my lack of proper searching (hypocrite moment).
Anyway, Building a 402 @ 10.5:1 with 42LBS injectors and was wondering if a boost-a-pump would get me by, until I Pull the full system for a cell in the trunk and likely -10an lines.
Anyway, if you run a boost-a-pump on a V1 how much WHP are you putting down?
Also, since the stock connector is so notorious for melting stock...... was, or were there any problems running 17.5 volts to it?
Lastly, how did you install it? Tips? and pictures?
Thanks
Thanks
I'll be running a kb40amp bap. But it will be a while before I'm at the dyno and tunning. I did run the hotwire kit from racetronics and I'll be running a 2psi hobb switch so that the bap will only turn on when I'm in boost. Will see how it works also I'll be running ford racing 60lb injectors. Shooting for 530whp
I run the DW300 through the stock bulkhead connector currently (and checked frequently). I am in the process of switching out to a PWM fuel system. Part of the swap is to the Racetronix connector listed in Philistine's dual DW 300 sticky.
No melting but I am getting an EVAP error. Like I said fuel system work to be done.
HP - That is the subject of some debate. Long story... Conservatively, north of 600hp.
I've had a KB 40a single BAP for 3 years. Had an internal short once and had to replace it. No issues with the connector. It may even help the connector by adding voltage and dropping current.
IMO id be a bit nervous boosting a stock pump, especially after seeing all of these melted pumps and recall notices. Just my 2 cents tho.
While I've not had issues using the stock bulkhead connector either, I don't want to find out that I have an issue by leak gas on hot exhaust pipes. You know what they say about an ounce of prevention...
Otherwise I agree. A BAP is not the evil thing that most make it out to be.
I think it mostly depends on the fuel you want to run. If you're staying with normal petroleum pump gas or race gas, cool. If you want to go E85 or some other alcohol blend, stock system is less than ideal. You need 30% more fuel flow to achieve a given power level. Doesn't seem like the stock system could handle that all that effectively.
P=IV, the fuel demands haven't changed so if you assume P is constant then I drops as the V goes up. Just like why electrical power lines are high voltage so they can run smaller wires and minimize the resistance (losses and heat). Your losses through the wiring and connector are P=IxIxR. So with the lower current your power loss is lower and it heats the wire and bulkhead connector less.
I hear you BUT the pump will pump more fuel when the BAP kicks in. That is the whole purpose of the BAP. If the amount of fluid pumped goes up then the work or power increased. Which translates into more current. This assumes you are not on a PWM system (like ours). If you are on a PWM fuel system you would be correct.
Magna volt booster pump issues
05 GTO ls2 tvs 1900 Maggie 2.8 pulley 525rwhp, kooks lt w/high flow cats, aem cai, B&M shifter, koni shocks, white line rear bushings and motor mount ,12 flat @110,I can't drive a stick lol. Things have been acting up and I think it all points to the bap, melted coil harness repaired, still missing on #3 plus ping under power, waiting for answer from from above, don't wanna blow this motor!
