Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
V2 to V1 Rear Subframe Swap
Old 09-16-2016, 03:35 PM
LSX416's Avatar
Default V2 to V1 Rear Subframe Swap
I put a V2 rear subframe in my 2005 V1 last week. Was surprisingly easy.
Here's a quick summary of what I did to make it work.
I bought a base v2 cts rear subframe from a junkyard along with base cts right and left suspension assemblies. Found a diff and axles from an M6 v2 on ebay.
I wanted to keep the stock wheels (don't ask why, I may change them in the future) so I found that a front wheel bearing hub from an 03 Pontiac Aztek (ironic?) will work. It's 33 spline, 5x115 bolt circle and the speed sensor is the same as ours, but needed to be re-drilled. I welded up two holes and had it drilled to 6x115.
I used the v1 rear e-brake assembly so I could use the stock v1 rotors. The v1 caliper bolts right up to the v2 spindle. The v1 e-brake cables worked in the subframe, one just needed to be shortened by 1/2''. Crimped on a new end and the brake holds great.
Put the subframe in, had to order the correct length m14 and m16 bolts from fastenal.
Stock v1 gas tank cleared without modifications.
I used the stock v1 rear shocks and springs. Had to cut the springs 1/2'' to get back to stock ride height.
Had a custom 3.5'' aluminum driveshaft made by The Driveshaft Shop.
Got the car aligned yesterday and was able to get it to factory specs.
Did a 4k rpm launch and NO WHEEL HOP. Also, no more gear whine on the highway and no vibration. The rear suspension doesn't squeak or clunk when going over bumps like it used to.
The car drives completely different, this is the way the car should have came from the factory.
The only issue is that the wheel is out about 1/4'' more than stock. Not a big deal and it doesn't look bad.
Attached Thumbnails V2 to V1 Rear Subframe Swap-20160819_182303.jpg   V2 to V1 Rear Subframe Swap-20160819_182316.jpg   V2 to V1 Rear Subframe Swap-20160819_193715.jpg
Old 09-16-2016, 03:56 PM
raven154's Avatar
Now that's pretty slick. What was the total cost?
Old 09-16-2016, 04:14 PM
Mercier's Avatar
That's pretty badass man! How's the strength of the V2 diff vs 4th V1 and 8.8? Are gears available for the V2 diff?
Old 09-16-2016, 05:13 PM
actrite80's Avatar
I like it do you know if the V2 fuel tank will work
Old 09-16-2016, 05:52 PM
ls1247's Avatar
Somebody tried this back in 09 or so and said you'd have to use the v2 gas tank. Glad you tried it!
Old 09-16-2016, 06:11 PM
FuzzyLog1c's Avatar
Fantastic work! Now we've gotta find a guinea pig for the aluminum V2 front subframe.
Did you notice any weight differences between the units? Any differences in clearances?
Old 09-16-2016, 06:14 PM
TorchRedRob's Avatar
That's awesome! I remember the original thought was the gas tank wouldn't fit with it, and you'd have to relocate the upper shock mounts or something. Sounds like that was all bogus. Looks like another bolt-in option to fix the rear now exists. Good work and thanks for sharing! I was hoping someone would try this one day and figure it out.
Old 09-16-2016, 06:35 PM
Mercier's Avatar
Funny how even when it's somewhat no-brainer it takes someone just taking the time to try it.
So give me some deets on durability and gear availability? Still putting mine together so plenty of time to agonize over whether or not this is a wiser path.
Front cradle is exactly where my mind went; love to lose some weight up there. If that works and someone would FINALLY MAKE A GODDAMN HOOD WITH MORE CLEARANCE AND NOT JUST VENTS we could redneck our collective way into V2s without having to actually buy the car.
Old 09-16-2016, 06:54 PM
FuzzyLog1c's Avatar
I wouldn't call it "redneck our way into V2s." The V1 is a legitimately good platform, once you correct the shortcuts GM took to develop this car. In theory, a fully-outfitted V1 should be 300-400 lbs lighter than a V2--it's the size and weight of the ATS but with provisions for a supercharged or turbocharged LS-series V8.
Anyway, this is why I keep looking for cheap V1 and V2 front subframes. If I can't make a V2 front subframe work, I'll settle for a < 1" reduction in engine height on the V1 subframe, even if it requires cutting and welding to clearance around the oil pan.
Old 09-16-2016, 08:46 PM
Mercier's Avatar
I didn't mean to insult anyone... Just nice to do the cheaper, lighter version. I embrace my redneck. Didn't mean to apply that to anyone else that didn't want it.
Old 09-16-2016, 10:07 PM
Mercier's Avatar
You know...like this..
Best I can do to explain my love for my car.
Old 09-16-2016, 10:17 PM
jmilz28's Avatar
This guy goes full epic within 5 posts...impressive.
Old 09-16-2016, 11:37 PM
gtistile's Avatar
In B4 you start crying about how this was your idea and you were drugged and raped while it was stolen from you. **** off
Old 09-16-2016, 11:45 PM
FuzzyLog1c's Avatar
Old 09-17-2016, 01:30 AM
Brackets's Avatar
Props to LSX416 for seeing this through.
Never go full epic!
Old 09-17-2016, 02:02 AM
lowoctane's Avatar
Specs on driveshaft?
Old 09-17-2016, 07:04 AM
ls1247's Avatar
This idea was floated the day the v2 came out as we're the 3rd or 4th generation of V1 owners to understand that the car needs help and that this could be a solution. It was just a matter of time that the parts got cheap and plentiful enough for it to make sense for someone to just buy the parts and try it.
Nice work LSX416. CS will probably start running clearance specials on their 8.8s....
Now...if a V2 driveshaft would be a bolt-in, this would be an absolute slam dunk.
Old 09-17-2016, 09:44 AM
odthetruth's Avatar
http://www.ebay.com/itm/08-13-CADILL...pWWLcc&vxp=mtr
Base V6 rear cradle like that? I'm already on 8.8 but I'd like to just clarify that for myself.
Old 09-17-2016, 10:00 AM
gtistile's Avatar
I am super stoked to see this has been done. There is conflicting info about this though as I have been told the subframe doesn't line up for a strait bolt in. Either way, this is huge for the V1 platform in my opinion. Well done LSX416
Old 09-17-2016, 10:02 AM
FuzzyLog1c's Avatar
Don't jump to conclusions. We don't know if this does anything yet. More testing is required.
Quick Reply: V2 to V1 Rear Subframe Swap
