Fml...
Fml...
Ok. So I tried to fix my old a** headlights that were pretty badly weathered... And well... I f***ed them up even more. So my questions to anyone who has replaced the assemblies... Has anyone did the eBay ones and converted the wiring from the d1s too a different bulb setup? Example... If I were to buy the headlights on fleabay... They were for non HID and non washer. Which I don't really need the washers. But if I cut the d1s pigtail and wired in the pig tales for the correct assemblies' bulb like a stock CTS bulb and buy my own HIDs. Is it possible? Or am I going to do more damage than good? And find a set of new headlights that are plug and play set?
Not sure if it's my wording but I couldn't find a write up on what I'm trying to accomplish.
There's just some questions about the switcheroo that I have and would like to confirm before I pull the plug...
Just get a set of aftermarket headlights without the washers, and a 50W Morimoto Elite H7 kit with 4300K bulbs.
As delivered
Professionally painted black surrounds
As delivered
Order a new set of Depot headlights.
Rock auto carries them and they are fantastic.
They are a factory replacement for the OEM headlights.
Search the part numbers on these screen shots for better pricing. They are complete and ready to install from the box. They include HID projectors, ballasts etc total plug and play ready to go.
Works out about the same price as fuzzys recommendation, but you don't have to futz with anything. Just open the box and Install. Headlight washers function as normal.
-Byron
-Byron
As delivered
As delivered
The fitment isn't perfect and the wiring sucks (you typically have to cut the wiring connectors off and do it manually), but in the absence of a better option, I like them the best. What I'd really like is a headlight with a single Morimoto FX-R (Bi-Xenon), a LED DRL array, and a vertical LED strip turn signal. But the people designing the aftermarket headlights don't seem to understand the strengths and weaknesses of the platform.
As delivered
As delivered
I bought similar assemblies, but they take a 9006 bulb. I then purchased my own set of HIDs. Just worried about how they hook up and what I need to get in order to have everything ready before I rip the bumper off.
