Difficulty shifting into reverse...
I found some older threads on what sounds like this issue but besides being very old they also seemed to go down several rabbit holes and not always coming back out. I'll list the threads below for reference. I'm wondering if enough time has passed that this has become better understood and there is a more focused set of possibilities for it.
The car sometimes just cannot be coaxed into shifting into reverse if the engine is running. Turn it [and the key] off and it shifts into reverse easy-peasy. Turn the key back on and it still shifts into reverse easy-peasy. Start the engine and it's back to original symptom -- sometimes will shift easily into reverse several times, even days, and then will just as suddenly be impossible to shift into reverse with the engine running. When it does go into reverse its a clean shift -- no funky feel or sounds.
It has a Creative short-throw adjustable shifter and shifting into various other gears before trying reverse seems to have no effect.
The previous owner said that the tranny fluid has been flushed and refilled with synthetic - I assume he was talking about the clutch master cylinder - so perhaps he was trying to fix this issue.
The clutch feels smooth and all other shifts are crisp, quiet and clean.
Anybody have this exact experience and, if so, what did you do to troubleshoot and fix it? Or are familiar with it and know what needs to be done?
Thanks in advance,
Howard
Seattle/Redmond, WA
The threads were:
http://www.cadillacforums.com/forums...reverse-2.html
http://www.cadillacforums.com/forums...lem-fixed.html
http://www.ctsvowners.com/forum/35-t...ocess-pmc.html
Thanks in advance,
Howard
Seattle/Redmond, WA
The threads were:
Could be shifter rail bushings and/or sagging transmission mount. You aren't going to find many definitive 'here's my shifter problem and here's the solution' threads. There are multiple things wrong with the way the shifter is set up and the materials used. Plus some hokey mods that the PO could've been into or reasonable things done wrong. Start with tge simple ones and work your way through it.
https://creative-steel.com/shop/04-07-cts-v-shifter-bushings/
the ones im talking about are the rod support bushings. $25 and simple install from inside the car.
https://creative-steel.com/shop/04-07-cts-v-transmission-mount-2/
i dont know if its wise to do this without stiffer engine mounts too. Maybe just replace tge trans mount with a new stock one. I have this instead:
https://www.revshift.com/mobile/Product.aspx?ProductCode=PTI-CTSV
My car is a little hard to get into first and reverse. Mine goes easily in if I start to release the clutch as I give a light push on the shifter.
isis do you have a link for the rod bushing install?
Thanks fellas. It'll take me a while to digest all of this. In the meantime, are you talking about something different than the Creative steel bushing kit I already have installed?
Usually when they shift into 1st/reverse easily when the car is off but not when the car is running it's a clutch release issue. If the clutch isn't fully disengaged it's still putting a load on the transmission (spinning) The slave has to push the pressure plate in enough to lessen the load on the transmission so it will slide into gear. The usual cause is air in the line between the clutch master cylinder and the slave cylinder so it needs to be bled out.
Thanks LLLosingit. Sounds reasonable. I'll give that a shot 1st.
I'll update this thread with the things I try and the results I get.
Howard
Howard
I did some searching for the correct bleed procedure. What I found was from 2010 and the pictures and links didn't work. Also, a Sears p/n for a special tool that will fit on the bleed valve was referenced but not given. I've got a downloaded 2009 Service Manual that I'll look at tomorrow.
Edit: https://ls1tech.com/forums/cadillac-...verse-fix.html
Just ordered this little guy -- ha ha About half the reviews were really positive and the other half really negative. Go figure...
When it comes in I'll use it and my friend's Motive Power Bleeder to flush the old fluid and any air out and refill it with nice new DOT4.
I'll let you know what, if any, difference it makes. ...as well as how the little bleeder wrench worked.
Motion Pro 08-0482 8mm Mini Bleeder
One last post to close this thread out.
Before we could do anything definitive about the problem the clutch pedal started occasionally staying down when depressed. Fortunately it could be pulled up by hand and would work for a while so we used that bit of good fortune to get it over to a repair shop that specializes in Corvettes and Vs. Turns out, the oil pan had been seeping [for no telling how long] and though not enough to draw our attention from oil spots on the ground it was enough being blown back that over time it soaked and ruined the clutch. Humpteen dollars and a re-sealed pan and a new LS7 clutch later it is working great and never fails to shift smoothly into any and all gears. Took the "opportunity" to install a remote bleeder while everything was opened up.
Obviously my preference would have been to be able to fix it with a fluid flush or mc/slave replacement but in this case that would have just been a waste of time. Sometimes you just can't simply wish the expensive solutions away.
Thanks all for your help with this.
Old (original) clutch
