Clutch Master Cylinder Options
Is there a better option for a clutch master cylinder on these cars? I’ve rear that Philistine used to make one using either a Wilwood or Tilton mc but it seems like he’s stopped making that piece. Are there other bolt in options?
After having Tilton and Wilwood master cylinders fail, I went back to stock. I don't know what it was about my car that the PMC didn't like, but I spent way too much time ******* around with it and can't say I saw any appreciable improvement in clutch performance or feel.
I’m torn. I need to bleed the system to see what’s what because some days it will shift well, but not awesome. Usually if it’s cold out it will shift better but then the pedal feels like a sluggish sponge. I’m thinking there must be either air in the lines, the mc is done and can’t push the needed fluid or the fluid is done. The car only has 112k kms on it and I’m trying to figure out if the mc is dying or what since there are random times when it won’t let downshift with out rev matching almost like there is a block in front of the shift gate.
My stock unit has performed just fine, so I don't see any reason to replace it with anything other than stock. I'm at 189k and it could use some new fluid (actually haven't flushed it in 90k), but otherwise I have no reason to suspect it's bad. At 112k it could be a number of things if it's all original.
If I switch it out I’ll probably stay stock as that seems to be the common choice. One thing that makes me think it’s the MC is that if I’m coasting in first gear with the clutch in I can feel something happen in the pedal and then the clutch start to drag where if I try to take it out of gear I can’t and I need to let the clutch out, put it back in and then it’s good. I can’t figure out if that’s the MC or if there is air hiding in the lines. I’m going to do a big flush/bleed this weekend and see if that solves it.
I got a PMC in November (he does still sell them, just PM him) and if I could go back I probably would’ve gone with something else. Nothing wrong with the PMC, it works exactly as advertised (install was a bitch, but that will be the case for literally any mc on this car) but the stiffness is a bit over the top for a DD if you have a commute with a lot of traffic. I can drive the car fine, but it gets tiring.
I’ll probably switch MC when I go LS7 clutch.
YMMV, again, the PMC works exactly as advertised, no faults there.
I went back to stock. Ran an ls7 and my current twin disk just fine and with considerably less pedal effort.
Buy a centric brand master and save the cash for other mods.
Many people however disagree with me on this. Your mileage may vary.
There was absolutely zero gain other than replacing a worn master with a new one in my case.
-Byron
