Slipping Belt
Belt slippage is tough to combat. I've heard of people using VHT (traction compound for tires) on their belts with good results. Not too sure how messy it is. I plan to use some if the 2.6 starts slipping.
Can I ask how you know it is slipping?
WW
P.S. - I've also seen pulleys that have "cogs" machined into them so that they better grab the belt. Not sure where to get them, but a competent machine shop could likely modify yours.
WW
I've seen them actually spray it on the belt.
Are you sure your belt isn't jumping a groove? I had the ground up rubber you're talking about and had a belt that was trying to jump a groove. Replaced the belt with one that is "cogged" - or doesn't have continuous ribs - and all has been well since.
VHT or any tire compound is very sticky stuff. I actually intend to prep the belt well before install. It could be quite messy - but I know plenty of paxton/vortech/etc. style s/c guys using this trick. Not sure how long it lasts though.
Dayco makes a new belt called a "polycog". It supposedly is more flexible and provides better contact with the pulleys. They also claim it runs cooler and lasts longer. I bought a serpentine belt of this type for an SUV when the old belt was slipping and it has worked great for the last 3,000 miles.
