cLUTCH PEDAL STUCK TO THE FLOOR AGAIN!!
What to do now??I just put a new clutch in .A spec stage 3f it holds great but if I dump the clutch off the line after 2nd gear the pedal is stuck to the floor.
Anyone else had this happen? I guess its time for a new slave cylinder and a adjustable master cylinder.
![Punch](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_punch.gif)
Not sure if it'll help, but my car used to do the same thing in aggressive 2nd gear shifts. There is a TSB on this and the dealership just replaced a pedal return spring?? under warranty. Not sure if that's your issue though...
I followed Ranger's guide line & never had a problem with the clutch on my '00 Corvette. A sticking clutch pedal is nothing new. Try it, it will work.
http://www.rangeracceleration.com/Clutch_Care.html
Originally Posted by Jake@EPP
All the issues i have seen with pedal stick on these is problems with the master cylinder. This not a fun install either, but it is the only fix ive seen.
![Werd](https://ls1tech.com/forums/images/smilies2/werd.gif)
also check your clutch fluid.
my pedal did this once and i had low fluid in the reservoir.
