Not Cracked Grenaded!
i "Grenaded" my differential and so says harrys cadillac its was customer abuse would it be worth doing this so called "rear end fix". and if not then i also need a differental, anyone out there have one just lying around that they would sell?
Jeff
Unless you have modded your car, I would challenge the dealership, and then go to Cadillac Assistance if still denied. 'Customer Abuse' is a very relative term, you own a 400HP luxury performance sedan, and 'spirited driving' is acceptable/commonplace.
Good luck
Good luck
I would consider taking to another dealer too.
-Chris
I see you are in Asheville. If needed you could ship your car up to Alexandria VA, and get Lindsay to fix it. Unless you are crazy modified, I'd bet they would fix it under warranty.
I'm on my 4th. All swapped at Lindsay.
-Chris
-Chris
I'm on my 4th as well. The 1st one was when I was stock, the 2nd and 3rd went after adding a supercharger. All were warrantied b/c they KNOW the car has a POS rear end. Find a different dealer that actually knows what their talking about. This crap pisses me off.
I agree with all of the above - that's a warranty issue. Look at that NHSTA...or whatever...thread that is stickied above. The government is investigating the rear-end failures. Screw that - GM should be buying your first without question.
This is simply a dealer taking the easy route of denying. If you start shouting NHTSA or Advertising then they'll throw you out on your ***- I recommend calling Customer Care and explaining what happened, as well as the fact that the rear diff is a well known issue with these cars. The person on the phone will tell you they've never heard of it before (script), but I would be surprised if they didn't call the Dealer and have them replace it under warranty.
Good luck, and remember that you catch more flies with honey than vinegar.
If you're looking for an OE diff, there is a fellow advertising a new OE for a V on ebay. That was at least as of yesterday. Speaking on 'grenading'. I had the experience of being the participant of an explosion when I was with the service director at my servicing dealer. Thank goodness he was driving, and it wasn't my car!
There are certain dealerships that are aloud to do mostly everthing under warrenty, it is based on how much Revenue they produce. Smaller dealerships don't have the same perks as big volume dealerships, Lindsay, Sewell etc. This is what my Caddilac dealership said to me...I would argue with them....My Z06 (25k miles, 03)is in the dealerhsip for its 4th transmission issue and its all under warrenty....they know exactly what I do with that car...rag it...
