Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Kooks Headers /Corsa Exhaust Vid Clip
Old 03-21-2008 | 11:54 PM
RangerRob's Avatar
Default Kooks Headers /Corsa Exhaust Vid Clip
here's a clip of my exhaust, it was 50 degrees out yesterday so i cleaned it up, and then it snows like 7 inches today, go figure... anyways, if it gets revved over 4k it sounds like something is rattling, is that normal? it sounds like something is loose or vibrates, let me know what you think
http://www.youtube.com/watch?v=8b2GqO_um_U
Old 03-22-2008 | 01:04 AM
modsdone's Avatar
Ranger,
No cats, right? Sounds like some exhaust rasp. Sounds a bit aggressive!
Old 03-22-2008 | 01:05 AM
RangerRob's Avatar
no cats, would having cats get rid of the rasp? not a big fan of it, even though it does sound kinda cool... any advice on how to get rid of it?
Old 03-22-2008 | 01:11 AM
cookba's Avatar
ya some magnaflow metallic cats will take that rasp away. sounds good though, it'll sound "cleaner" with the cats and i think you'll like it more too
Old 03-22-2008 | 01:47 AM
modsdone's Avatar
As the man says!
Old 03-22-2008 | 01:51 AM
dochall22's Avatar
Your gonna blow it up!!! - thats what my dad always says when I do exhaust vid clips -
Old 03-22-2008 | 09:16 AM
Tony Orlando's Avatar
I wouldn't count on it- I have that exact same setup (Kooks, MF cats, Corsa) and it's very raspy with that same "death rattle" when the RPMs fall.
Question: When you floor it with your windows down, does it start making a "flapping/clacking" noise from 4k up? I've spent almost $300 changing gaskets and getting things welded in an effort to track it down, and no luck.
By the way- rock on, Rangers. My Brother's in the sandbox right now with the 1st Ranger BN.
Old 03-22-2008 | 11:54 AM
trukk's Avatar
That isn't 'rasp', it's the infamous "Corsa Rattle". After a few month's the welds in the rear can's loosen up a little, and on decel, it will rattle/buzz. It does this untill the exhaust get's warmed up and expands. It's definately the rear cans, as I replaced my resonator, and it didn't make a difference.
I heard that they had fixed this issue with the new versions.
I just haven't got around to contacting Corsa to get a replacement set of rear cans. Corsa has a lifetime warranty on their products for the original purchaser.
-Chris
Old 03-22-2008 | 12:54 PM
Big Bu Bu's Avatar
Rob
I'll be setting up the same with the cats in late April. I'm pretty close to you (15 minutes from Gurnee). Maybe I can let you hear mine. If the snow ever melts! How did you like Speed Inc? Did they do the installs as well as the tune?
Mike
Old 03-22-2008 | 01:24 PM
RangerRob's Avatar
ya it does it on WOT over 4k also... makes me cringe...
Old 03-22-2008 | 01:27 PM
RangerRob's Avatar
Originally Posted by Big Bu Bu
Rob
Mike
ya that'll be sweet, Speed Inc. installed my headers and short throw and tuned it, they definitely know they're stuff! the exhaust was on it when I bought it, Mike, are you going to their open house at the end of april?? Trukk, is there anyway to have them fix mine even though I'm the 2nd owner of the car???
Old 03-22-2008 | 02:23 PM
trukk's Avatar
RR,
I'm not sure. The best bet would be to call Corsa directly. I had an issue a while back where I lent my car to a friend, and he ran over a lawn gnome and slightly dented my original corsa resonator. I called and talked with Jim Browning, Jr, and eplained the situation, and he offered to sell me just a resonator by itslef, which is something they usually don't do. He was very reasonable to work with.
I'd call and talk to Jim.
-Chris
Old 03-22-2008 | 02:32 PM
I'm thinking about ordering some Magnaflow canisters from Jegs and having them welded in place of the Corsas. I love the Corsa sound, but every Corsa car I've ever heard has the same death rattle on decel, so I'm not confident that replacement canisters will hold up any better than the first ones did.
Old 03-22-2008 | 02:36 PM
RangerRob's Avatar
Originally Posted by trukk
RR,
-Chris
thanks trukk, will do. I'm just confused on how it could be the catback, because before having the headers installed a few weeks ago, there was NO rattle whatsoever... it was a smooth clean sound coming from the corsa catback, didn't think the headers would make that kind of difference in sound, or effect the exhaust in this way...
Old 03-22-2008 | 02:58 PM
The rattle from the Corsas on decel has been there since day 1- the flapping/clacking noise under WOT didn't appear until I added the headers, which is why I've been bleeding cash trying every kind of gasket on the market- I thought it was the headers.
The more threads I read, I'm beginning to think the extra airflow at high RPM makes whatever's rattling in the Corsa on decel make the clacking noise.
Old 03-22-2008 | 02:59 PM
FYI- two Magnaflow canisters from Jegs (same part # used in MF catback system) are less than $200 shipped. I may go that route.
Old 03-22-2008 | 03:07 PM
RangerRob's Avatar
Tony, let me know if that fixes the problem!
Old 03-23-2008 | 09:16 AM
Big Bu Bu's Avatar
[QUOTE=RangerRob;8980767] Mike, are you going to their open house at the end of april??
I was thinking of going to check them out. Maybe we'll hook up.
Old 03-23-2008 | 08:25 PM
04ctsvfl's Avatar
I have kooks no cats and magnaflow, and mine makes wierd noises too. What would an exhaust leak around the gaskets sound like?
Old 03-24-2008 | 11:16 AM
Ticking.
