Alright sound off for your favorite CTS-V brake pad set.
Brake pads are on the squealer tabs on my V. I was going to use OEM anyone want to brag for a different pad set?
This is going to totaly depend on your application. Afew idea's.
1) The OEM's used to be (in '04 / '05) Ferodo HT1000's. I assume that they still are or are something comparable. These are damn nice pads. They do tend to dust a fair amount though. Mine never really squeeled though, which is nice. Mine laster about 35k miles
2) I tried Hawk HPS, ceramic pads. These barely dusted, and what did come off was a light cinamon color, instead of coal black like the stockers. The main issue with these, is they do not grab as hard as the OEM brakes. If you can deal with a bit less performance, and the break dust is killing you, these are an option. Another simialr option would be CarboTech Bobcats. I swapped these out after about 15k miles, as the performance loss was killing me. I ran these at the track one time, and had to buy new pads at the track, because these faded like crazy ( I couldn't even get the car into ABS after a few laps)
3) I currently run Hawk HP+'s. They bite harder than stock, and dust about the same. They do tend to squeel a bit though. I love the performance on these. They are a real confidence booster, especially in stop and go traffic. The car really stops now. These worked great at the track as well, untill I changed to R compound tires, whcih then outperformed these pads. I'm on my second set of HP+'s. Expect these to last approximately 25k miles.
4) I've run Carbotech XP10's at the track, and they stop like no ones business, and are very easy on rotors (unlike Hawk blues, or their DTC series, whihc just much rotors). The only downside is I went through an entire set in one weekend.
Hope this helps,
Chris
Hope this helps,
Chris
I put on a set of Monroe DX1053 and DX1001 on my wifes car a couple months ago and am very impressed with them so far.
They are much quieter then the stockers, dust dramatically less, and when they get some heat in them they really grab well. I don't track my car, so can't tell you how they are for that, but for the price on RockAuto I'm pretty sure they rock.
I put some raybestos on my C5, and they dust something fierce... I wasn't sure who I wanted to go with, which is why I didn't order the same mfg for both. Now I'm Monroe all the way.
Also I'm sure the Carbo and Hawk are much better track pads, but I have a hard time justifying paying at least double the price for my uses.
Jay
Jay
do you think these would be good for over 7-10k with street driving?
Here's a list of carbotech's pads:
http://www.ctbrakes.com/faqs.html#compounds1
I'd assume that the Bobcats are similar to the HPS's, and the Carbotech™ AX6™ (1106™) are similar to the HP+'s. A buddy of mine said he called Carbotech, and they recommended the XP8's as the most agressive pad that could do still do street duty. I'd try the AX-6's first though. the HP+'s I have now really grab hard, and aside from comming fresh out of the car wash, I never have any problem with them not being warm enough to work. With the XP-8's you'd probabaly have to be a bit cautious, as they need to get up to at least 200 degrees before they start to work well.
For all those tuning out on this discusion, don't discount a minor brake pad compund upgrade. It really enhances the driving experience. People easly shell out $250 bucks for a CAI that shows minimal gains. For the same price in brake pads, you'll see way more than a minimal increase in stopping power.
Whenever I take my friends out for the first time in my car, they really like the acceleration. I always tell them you haven't seen anything yet, and do a really hard 75 to 10 mph decel, and the usual description is "holy **** !!"
-Chris
oem on a NASA track where horrible. After the first time around the track the brakes no longer work at all.
I switched to a custom compound that was made and 5000% better. Yes they are squeelers... But, they do thier job and they do it good! Rotor life is bad, they do dust, but, well, this isnt a normal caddy we all are driving. LOL
I think they cost me 800 bucks for the pads, I do have another set if any brave souls out there want to be able to lock up all 4 tires at 160mph if needed.
That's what she said...
I replaced the stock pads/rotors with drilled OEM rotors and Hawk HPS pads. The stopping power was noticeably reduced, but it will still stop 2x as hard as 99.99% of the other cars on the road, and that's what I'm concerned about.
I notice very little dust with the HPS, as opposed to 10lbs per wheel with the stockers.
If you had a stock HP car (thus not hitting crazy high speeds on the straights), with stock weight (less taxing to slow down), and OEM tires (sticky tires will outperform the OEM pads), you woul dhave been fine with the OEM's untill you got really good at tracking the car.
Great observation. Most people still seem to think that HPS's give similar performance to the OEM's. They don't. But you are dead on, that even with HPS's you are still stoppping great.
-Chris
Great thread so far. I want to do a complete brake upgrade in the near future. Good info here. Not to hijack, but any other affordable brake system upgrades? I'd love some two piece rotors and maybe even better calipers, but I think that's out of the budget for right now. I do have some stainless lines I need to put on. Any real difference there? I have some on my AWD Talon but haven't been able to drive it much.
PS - 06/07 center caps are awaiting install.
My $0.02,
Chris
The OEM brakes are one of the best features on this car. With aggressive pads, OEM rotors, braided brake lines, top shelf high temp fluid, Titanium shims and some brake cooling ducts, it should be a long time before you start outperforming your brakes. IMHO there are a lot of other areas to put you mod money before messing with the brakes on the V.
My $0.02,
Chris
My $0.02,
Chris
Source for the shims and ducts?
-Chris
i acctually like the little squeel my stockers let off now and then,
it reminds me that we have bad *** brembos holding things down.
and this little piggy went weee weee weee from 60 to 0 in 0 seconds.
ur stopped befor you start. <----in honor of "THE DEAN"!
CTS-V Shifter Sales
Brian
aka pisnuoff.
