Fitting red FRCs on ls6
I suspect at the least, you will have to cut the driver's side cover around the power steering pump reservoir. You may also have to cut the inner rear corners of both to clear that fuel line or a/c line or whatever that is back there.
Basically just try to fit them up, and see where it hits. Trim that, then repeat.
I believe the LS6 covers need a lot less trimming though, because they don't wrap down on the edges like the LS2 covers do.
I'm sure there's a tutorial around here somewhere, but I basically did what he said. You'll end up trimming a little bit off the front corner of the driver side one by the PS reservoir, and quite a bit off the rear/top of each FRC around the fuel rails.
Here's just some general circles of where I had to trim:
![](http://www.submariner.org/thepno95/Pictures/CTS-V%20pics/Dress%20Up%20Mods/Vette%20FRCs%20-%20red%20-%20trimmed%20spots.jpg)
Thanks for the help guys. I started on the drivers side and dremeled the areas you have circle but I need to dremel alittle more.
This is definitely on my to-do list. I've been trying to score a set of ls6 covers in good shape, but am always a little too late. They can be had new from gmpartsdirect for about $140 a pair.
