V turns over but won't Fire
2005 CTS-V
Drove it to work normally this morning, but went to start it at lunch and it turns over strongly, but won't fire.
Tried disconnecting the battery for a while. No change
Put in my code reader. No codes.
Checked fuel pump fuse under rear seat. Looks fine
However, I cannot hear the fuel pump priming when I put the key in the ON position. Can you normally hear it? I tried it with the rear seat removed. I can hear the fuse box under the rear seat on the passenger side click, then a smaller click 2 seconds later. I assume that is to prime the fuel pump I don't hear any other sounds from the back.
Go!
Go!
Well that sucks. I read about something shorting out on there. What exactly is that?
Sounds like I'll have to take it in. Its sitting in the parking garage at my work so I can't really drop the tank there. Maybe I can tow it home if it's not that hard to fix in a garage. Either the short or bad pump im dropping the tank and replacing something either way right?
car is in also Viejo, ca. I live in costa mesa.
You can saw an access hole under the rear seat instead of dropping the tank.
Do some searching and there is a template.
The failure is the terminal connector on the top (of course).
https://ls1tech.com/forums/cadillac-...g-smoking.html
I have the tool to remove the locking ring, if you need to use.
I am local to you.
I am local to you.
I haven't checked the relay, those things are so hard to get out anyway. Is there a way to tell if it's bad when I pull it out? Which one is it? under the hood or under the seat?
I guess I can just swap it with another one that I don't need that I know is good.
if it's the fuel pump connector will it be visibly bad when it comes out? I think I have to take it into a shop, I can't take the time to drop the tank and all that and I need my car.
In that case, what all needs to be replaced? Do I just get stock parts from the dealer? Any way to prevent this in the future?
Thanks guys.
Thanks guys.
Well i was both cheap and lazy i cut an access panel , pulled the pump said some profanities took some pics and called gm to bitch about it; then i cut the ground wire soldered on a new 12 guage wire removed what was left of the pin in the connector on top of the pump assembly , drilled a bigger hole where the pin was and ran my new wire through the top and sealed it .then i butt connected the new wire into the harness . I do still have some pics
Quick and easy ; reach under the car at passenger side of fuel tank and tap the tank strap with a hammer or ratchet it should jar the connection enough for the pump to run a lil while; that will tell you also
I know you said that you don't hear the pump running, but I never hear mine either. I would try to give her a snort of ether and make sure it fires and runs even if it is only for a second. It would eliminate the 100 other things it could be.
