"HOT" e-tests anwhere???q
that makes no sense, did you get that from drive clean itself or word or mouth? The chassis year is whats used to allow it qualify for hot rod status not when the motor went in. There is alot of bad information out there regarding drive clean, they even told me 1 thing then called me back within the hour to correct their mistake.
as someone who struggled to get his 88 TBI to pass, I can tell you NOX is all in the cylinder temps and EGR operation. You need the EGR to be working near perfect with flow into the intake. Colder thermostat is only a problem if the fans turn on at the same temp, else your engine will be at normal operating temperature the fans turn on at.
The cats will only help to clean up CO and HC numbers, so if the cat is going, those readings will be high.
On the ls1 I think the EGR is a waste. The Vettes never had one with the exact same motor! The 2001 and 2002 never had them and made more power with lower emissions. It can be tuned to pass IMO.
We will see how mine does with its little cam, though it is eligible for the Hot Rod status.
![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
We will see how mine does with its little cam, though it is eligible for the Hot Rod status.![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
I got it from the Ministry's online documents.
(2) A hot rod that receives a motor replacement on or after January 1, 1999, shall receive a motor designed to meet emission standards at least as stringent as those achieved by the original motor with all its original emission control equipment attached and functioning, and the replacement motor shall have the original catalytic converter and all the original emission control equipment, or equivalent replacements, included or usually included with the replacement motor by the manufacturer of the motor. O. Reg. 361/98, s. 4 (2); O. Reg. 86/99, s. 3.
See the link:
http://www.e-laws.gov.on.ca/html/reg...s_980361_e.htm
Do you read it differently? I might be misunderstanding it.
Sorry I just noticed this.
See the link:
See the link:
#34
As I recall, if the engine was available for that year say 92, ie say someone did a 305 to 350 swap, it would NOT be eligible for hot rod status.
LS1 to LS6 doesn't change the cubes and it was offered in 02 albeit unofficially. No dice there either.
LS3, LS2, LS7 would be eligible in a LS1 based car provided for those years it was not offered.
#35
I talked to the MOE today and had it clarified that yes I would qualify for the Hot Rod status and that it is block specific, not displacement.
Now I got really brave and called the inspection unit and I am waiting on a call from the supervisor. He is supposed to be the best one to clarify what equipment needs to be installed under the hood. I only have one question though, do I need the EGR, since the motor I have installed never had one. I have every other part installed that the car came with and II think I can make the EGR fit int too, but my headers do not have the fittting nor does the Harrop. So it would be a lot of custom work.
#37
Well, it is sorta of, kind of, nearly, ummm, no!![Embarassed](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_emb.gif)
Very close now, I am putting in fluids, finished wiring, now I need to do some fiber glass work and 6 aluminum welds.
I will have Redline install the y pipe, drive shaft and an intial tune. Plus check to see if I have screwed up anything. Hopefully ship it out of the garage on Friday. More likely on Tuesday though. I have learned a lot, including not to take on a project like this again till I retire. If it all works out I will be very happy.
#38
#40
Just to let everyone know, I put a magnaflow cat on my 3rd gen and it passed. IIRC it actually did quite well, but it has to go again next year so I will see how well it does long term.
