Canadian Members We never leave because we have The Beer Store
sizing injectors
Old Feb 20, 2012 | 05:55 PM
LETZRIDE's Avatar
Default sizing injectors
Anyone familiar with sizing injectors? My car seems to be maxing out 36#'s at the moment (heads/cam) setup. From the Hp tuners scan from the day I was at the dyno she seems to be running the following at 5300rpm I am at 78-80% injector duty, by 5600rpm I am at 88%, and 90% by 6000rpm. At the start of the run at 4900rpm I am as low as 69% duty.
As far as future mods in the forseeable future it is most likely limited to upper and lower intake manifold swap and PP work to both respectively.
Car will remain N/A
I also already have a walboro installed (same one for the Lt1's)
Old Feb 20, 2012 | 06:20 PM
95mysticta's Avatar
That sixxer must be making some serious power if your maxing out your 36lbers!
This is a good site for calculating your injector sizing.
http://www.rceng.com/technical.aspx#...cted_Injectors
Old Feb 20, 2012 | 07:22 PM
LETZRIDE's Avatar
Sweet thanks. Quick question though, is that horsepower at the wheels or at the motor that they are referring to in the equation?
and
we'll see what kinda power/potential it has if/when I can afford to get her to the track this year!
Old Feb 20, 2012 | 09:57 PM
SladeX's Avatar
usually at crank, also don't oversize injectors.
Old Feb 20, 2012 | 11:13 PM
LETZRIDE's Avatar
hmm, what happens if you oversize? I'm guessing it will just be impossible not to be running rich?
Old Feb 21, 2012 | 04:54 AM
95mysticta's Avatar
Are you running a ladder bar or torque arm setup with your 8.8? Did you get it done by Cam?
Old Feb 21, 2012 | 09:06 AM
LETZRIDE's Avatar
torque arm setup, and yes it was built by Cam.
I haven't done much research into the ladder bar setup yet, I do want to get this torque arm off the trans though, not sure if I'll go that route or a torque arm kit that relocates the arm off the tailshaft.
Old Feb 21, 2012 | 11:18 AM
95mysticta's Avatar
Nice... im having him build me one this year too! Cant wait for some 5k dumps without having to worry about breaking anything!
Old Feb 21, 2012 | 12:32 PM
LETZRIDE's Avatar
Ohhh ya...cars 1000 times more fun when you're not having to baby the glass rear end. FYI, if you end up getting the sealed wheel bearings (from what I understand there are 2 types), ask moser for the inner seals...they say you don't need it, but they're dumb....cost me 3 bearings in less than 2000km...they kept telling me there was a problem with my rear end (yet the bearing was leaking through the middle of itself, not the outer seal portion)...needless to say the 5$ inner seal solved my problem
Old Feb 23, 2012 | 04:06 PM
warp10's Avatar
This is weird since I'm also running 36# and not maxing them out.
Old Feb 24, 2012 | 09:37 AM
fastcars95's Avatar
That because you have 8 of them and he only has 6
