Emissions?
So if there is no Nox, what are they testing? Hc and what?
Would the old trick of adding methanol I think it is? To the gas work/help?
The info on the drive clean site is so vague...
Im wondering if going too lean will throw the readings off.....some of the criteria is excessively too lean/rich condition.
With a cammed engine the oxygen sensors get confused and the pcm corrects rich. Leaning it out will make it a lot cleaner out the tailpipe.
Would you run into the problem of the machine rejecting it due to dilution? I wouldn't think so? to my understanding the dilution happens due to Oxygen being introduced no?
It just might work though.
I remember reading something about de-activating emission systems with HPtuners and I won't show as a failure.
My turbo car has no emission equipement. I'd like to be able to get a pass.
That being said, the testing has been changed, again (!), to allow a couple of status not ready as long as SES in not illuminated. Call drive clean 1-800#, get the info and go to the testing facility. My experience has been that the testing facilities are NOT really aware of all the ins/outside of this stuff, they're good at processing credit cards that's about it.
If you just turn the sensors off I believe it will show up as "not ready" although I think this varies for different cars.
