Emissions?
With a LS1 224 cam on a 0.561 lift and a 112lsa, stock heads, long tubes, true duals I was still well within 98 LS1 limits which are just as tight. The idle had a good chop to it.
I passed again at a random testing facility on a 230 0.615 115 LSA cam and 5.3L heads.
Now factor in that you guys also have 2 cats, while we have 1, and consider that my shitty aftermarket one probably blew half the contents out...yes my tune went pig rich as I didnt compensate for the cylinder I disconnected (injector/spark) and the car tried to compensate. Yes the tune will make a bit of a difference, not 4000ppm worth
If both are a go, I'll be looking for a pair of cats....I'll know in the next month/few weeks I think.
Car passed the 2500rpm, still failed idle with a 953ppm and a 2.0 CO% (200ppm and 1.0% allowed)
227/229 still isn't overly aggressive. My old 210/220 cam passed with flying colours
Bottomline is anybody that has a BIG cam, isn't passing the sniffer, and when I say big cam I am talking to anyone who has something above 230+ duration. I think the lift effect is very minimal
The more I think about it to, it could be shop dependent/equipment dependent. Case and point...I went out to a honda dealership for the first test, and ran with my cutout open and with 1 cylinder pulled. Today I went to a different shop, ran with all cylinders firing and my cutout open and the tech couldn't even start the test due to dilution. Oddly enough the honda tech only had one sniffer in, this guy had a sniffer in each tail pipe and it booted him, I had to go close the cutout and come back.
Anyways, I have what I need for now, I'll deal with this again in 2 years if need be, by then I should have LT headers and 2 cats myself, so maybe all will be well. Maybe they'll amend the law to include any OBDII equipped vehicle to do the new test like it is in the USA.
In any event, as I was waiting around at this shop I was at today...the number of people coming in for re-test/failing the new test today was incredible. I overheard a lot of the codes to, many of them were b.s O2 voltage high/o2 voltage lean bank 2, etc.
I have a little writeup I'm doing up to showing step-by-step how to ready up your sensors...when I have some time I'll complete it (has snapshots of where to go in hp tuners etc) as I've had a couple people p.m me already asking how to do it and being a little confused. I'll link it here when I'm done.
cheers and hoping to see some of you guys at the strip this season.
