Canadian Members We never leave because we have The Beer Store
Slowest CanadianTurbo SS 12.74 @115?
Old 10-04-2005, 06:23 PM
93-Z07's Avatar
Originally Posted by vmax1500
myabe go to another dyno to make sure you are putting out as much power as you think you are...
Maybe EugeneoSS should with his Camaro.............
600HP from his F.T.R stroker motor=12.4?
Old 10-04-2005, 06:55 PM
RAMPANT's Avatar
I could only go a best of 12.3@122 on street tires so Eugenio did not do to bad for a car that is 300-400# more than mine. He had a little stickier tire but still a street tire.
Tires on this kind of torque makes a big difference. My DOT slick drops me into the low 11's and maybe a high 10 but I'll have to see if I can manage that.
Rampant
Old 10-04-2005, 07:04 PM
C5Wade's Avatar
I wonder were YOU work? I could guess but I won't!
I guess it kills some people to see people happy!!!!!!
Old 10-04-2005, 07:41 PM
Brett H's Avatar
As others have mentioned traction is a big problem for you right now. As an alternative to ET Streets, I'd like to suggest trying MT's street radials. They are a great tire that hook. I just bought a pair of 16's for $190 each new.
Your car really pulled in the big end. Comparing your numbers to mine showed a huge jump in the last 1/8th. I pull 1.75 60's 8.0 @ 1/8th and trap 12.8 so to be 4 tenths behind at the 1/8 and still trap better the car must be moving.
i don't know a lot about turbos but from what I have gathered they make boost under load and need to stay spooled up so if you are shifting slow or getting out of it between shifts you will lose boost and therefore power. I think a few more track days will improve you ET's without touching the car.
Good Luck
Old 10-04-2005, 07:45 PM
denttech's Avatar
ARE you saying that a 5000lbs stick car on street radials going 12.3 at 125 mph approximately is something to sneeze at?
Old 10-04-2005, 07:46 PM
RAMPANT's Avatar
I think it was 118, not that I'm be-littling that. And more like 4000lb ish.
12.4@118 is awesome in that type of set up.
I have a similar coupe setup that is somewhat lighter 300-400lbs. It is not easy trust me.
Rampant
Old 10-04-2005, 07:55 PM
93-Z07's Avatar
5000lbs? 12.3@125mph?
Old 10-04-2005, 08:00 PM
denttech's Avatar
Good to give you something to laugh about, its usually the other way around.
Old 10-04-2005, 08:01 PM
C5Wade's Avatar
Dale I think Denttech was just trying to make a point, and you are right on your numbers, Eugenio told me that the car is actually closer to 4100lbs but I have never seen it on a scale.
Dale how fast do you think your car would go with an extra 400 lbs in it, this is not a flame just a fair comparison its easy to figure out I have figured it out allready, what do you come up with?
Old 10-04-2005, 08:11 PM
93-Z07's Avatar
So you agree it IS something to laugh about.....
Old 10-04-2005, 08:13 PM
RAMPANT's Avatar
I'm sure it would lose a few mph, but if placed well it would help with traction. Damn the first 2 gears are nuts on street tires. I'm sure Eugenio had the same issues even on the "R"s. Like I said to date the best street tire pass was 12.3@122 and that was tough as hell to get in good air.
I think Eugenios car ran as good as it would have with my motor in it. They are very similar, with only subtle differences.
Rampant
Old 10-04-2005, 08:15 PM
  #32
denttech's Avatar
My recall of numbers is, as are you.
Old 10-04-2005, 09:12 PM
  #33
93-Z07's Avatar
think about it, this summer my full weight Z28 ran 116MPH in 3000FT DA and it's only making 409RWHP now...
Think about it, this summer Eugeneo's car supposedly had almost ONE HUNDRED RWHP MORE than your full weight Z28 yet had an almost identical trap speed?
Intersting how you never pointed this out before........
Old 10-04-2005, 11:04 PM
  #34
vmax1500's Avatar
My superior driving skills have alot to do with that
It was Eugenio's 1st time driving the car at the track with a real motor in it...
Who are you... I know where you work, but am curious as to who you are...h
Old 10-05-2005, 05:57 AM
  #35
Lust4Thrust's Avatar
Default Who has 16" rims on rear and which tires
Since I need traction to compensate for my inferior driving skills.
1) Can anyone tell me what 16" rims will fit?
2) Does anyone take their 16" rims and strip tires to the strip change them out there? I am curious if how big a tire fits in the back of a camaro.
3) If not can I drive 2 hours gently on ET streets to the strip and back without burning them off?
4) With sticky tires I suppose I will also need a heavy duty driveshaft, as my stock beer shaft can won't last correct?
Tried a search, and couldn't find the information.
Thank you.
Old 10-05-2005, 07:59 AM
  #36
vmax1500's Avatar
Considering you have strong rear end, I say go for some 15" Convo Pros and true slicks... a 26x9 Hoosier slick will give you plenty of traction! Yes, you should upgrade your driveshaft and get a safety loop... You should have no trouble squeezing them into your car, I squeeze 4 Convo Pro along with a 15L jug of fuel and all my tools into my firebird and it has a roll cage in it! Don't try to drive to the track on your drag tires, I tried that at the beginning of the summer and 400kms of driving will kill your drag tires!
Thank you.
Old 10-05-2005, 08:01 AM
  #37
C5Wade's Avatar
Looking back on this thread and noticed that you have a alky set up, did you make this power with the settings you are at on your alky or have you played with it ? The alky is not add more make more power so if you have played with it this could be something to look at!
Old 10-05-2005, 09:13 AM
  #38
CHRISPY's Avatar
If you are going to run a full slick go with a 26x10 inch. Dont bother with the 9 inch wide tire. (You'll sixty about a tenth better in the sixty with the 10 inch versus the 9 inch)
You can also run a 26x11.5 inch wide ET street or QTP pro. (Measures out to ten inches wide) That should be good for a mid 1.5 sixty.
The 26x10 inch full slick will be good for 1.4 sixties provided you have enough power and gear.
I would buy the stickiest tire possible and change them at the track. Spend the money once
Old 10-05-2005, 11:19 AM
  #39
Great: 26 X 10, what size rim 16, 17?, 15" (don't want to grind calipers). Who sells them in Canada?
As to alchy. untouched since dynoed. Nothing changed since dyno, Other than...
I didn't have 94 octane as I did for the last dyno. Couldn't find it near the track and I was running on fumes. So I used 10 L of 87 octane and 10 L of 110 octane to try and get close to 94.
Was afraid running 110 octane might burn too hot or lean out my engine, unless I had it tuned for 110.
I have to do more research on this subject to determine what octane to run for the next track outing.
Old 10-05-2005, 11:42 AM
  #40
Bugblndr's Avatar
What is your goal for the car Lust4Thrust? I know lots of guys with 400+ RWHP who don't run much quicker than you if at all.
Quick Reply: Slowest CanadianTurbo SS 12.74 @115?
