Are you running a pvc system?
My LS2 motor has the PCV set up in the valley cover. I put a short piece of fuel line and a $3 clear fuel filter on the breather tube off the valve cover.
It is all visible in this pic. Really need some type of catch can in the PCV line. The lines have a trace of oil in them.
i run a pcv valve which links back via both rocker covers to my oil tank (dry sump) as a return line as the little breather filters will eventually get clogged by the fine oil mist the engines do produce when working hard.
