venting questions PVC
im trying to do my home work im reading about all this pvc stuff and im confused so im asking what are some of you carb guys doing. I have after market valve covers and was looking at the valley plate with the hole for the breather.
If you have an LS6 style valley cover you can hook the vacuum line to it then put a cheap $3 fuel filter and a section of hose on the valve cover vent (above the passenger side head). You can see both in the pic below. I have a generic PCV valve in the vent line right after the 180° turn (right under the front of the carb)
The LS6 style vent has internal baffling that is supposed to be better at separating oil than the LS1 vents on the valve covers. I get traces of oil in the PCV lines, so a catch can would be a good idea to keep oil out of the intake and possibly causing detonation.
Old School Heavy
Im running LSA valve covers with vents on either cover, no problems here. I didnt run anything on my LQ4 setup but had small amounts of oil coming from the factory tubes on the v covers.
