so what kinda PVC setup are you guys using?
Pretty much as the title says.How are yall hooking up your PVC system?I have mine hooked up the drivers rear valve cover with a PVC valve between it and the carb.Just curious...noticed these engines have alot of ventilation tubes on them.Im just running breathers on the passenger side valve cover and the valley cover.Been thinking about putting a catch can on it of some sort maybe and running something like that.
Check here.....
https://ls1tech.com/forums/carburete...tions-pvc.html
and here....
https://ls1tech.com/forums/carburete...vc-system.html
and even here for some ideas....
https://ls1tech.com/forums/carburete...questions.html
and here....
Just a little info to clarify...
PCV = Positive Crankcase Vent
PVC = Poly Vinyl Chloride (a type of plastic)
BTW...I will be using a breather on a valve cover.
