TKO-600 and 6.0 whos done it?
Im looking for other options as oposed to the T56 to mate up to my 6.0 to put in a fox mustang. Whos done it and what parts exactly do you need to make it work please? I am looking for a sipmler set up than the hydrolic T56.
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
I have done it, what you need depends, as there are a couple ways to do it.
I used my old BBC scattersheild, Mcleod LSX +.200" aluminum flywheel, Ls7 pilot bearing, self fabricated pivot ball mount welded to scattersheild, and modified oem mechanical clutch linkage. Use clutch of your choice. I use a Ram single iron drag clutch.
you could fabricate a mount/bracket to use your existing clutch cable to actuate the clutch instead of mechanical linkage.
I'm running a TKO 600 behind an LS2 motor. Bought everything from Kiesler engineering. I'm using their hydraulic throw out bearing though. I bought my GM specific TKO new from them also. They have kits for just about anything.
I think anything that will mount a Muncie will work for the TKO. Here is a short but pretty good thread about the topic, including a link to a complete kit from Pace Auto. You might call them and see if it works with a TKO
https://ls1tech.com/forums/conversio...our-speed.html
Another good thread with mechanical linkage info. try searching the conversion section for TKO.
https://ls1tech.com/forums/conversio...k-problem.html
Excellent info, Thank You guys. Doesnt look any easier than hooking up a T56 for me though, DAMMIT![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
I dont think the T56 is that cheap actually. ****,.. Im used to the T5 thats in the mustang now, they are a dime a dozen and you can find them for a couple hundred on craiglist. I will probably go with the T56 but I was just looking for the simplest bolt in and go method cause this is all new to me and Im not a real good fab guy.
Check with Quick Time Performance. They make a bellhousing (RM-6037) for mating a T5 to an LS engine. I don't know what else would be involved, but may be an option for keeping your T5 in place with your LS swap? Here are the specifics listed on their website:
RM-6037 - LS Bellhousing to Ford TKO 500-600/TR3550/T5 Mustang Transmission
Height = 6.925
Trans. Bore Ø = Universal 4.850/4.910
Engine = Chevy LS-1, LS-2, LS-3, LS-6, LS-7, LS-9
Trans. = Ford TKO 500-600, TR3550, T5 Mustang/Jerico 4-5 Speed
Clutch Ø = 11"
Flywheel = 168 tooth or 153 tooth
Weight = 22#
Full engine plate, trani ball and grade 8 bolts included
Height = 6.925
Clutch Ø = 11"
Weight = 22#
