Did I make the wrong choice
I am building an LS-1 for my s-10. It will be a semi daily driver. I have bought a used vic jr that was never installed and an msd 6010 with harness that was never installed. The cam I want to go with is 231/239 duration at 0.0050, lift is .617/.624 with 1.7 rockers on 113lsa. I am using a tr 6060 6-speed. The power band showes to 2000 to 7000 rpm's. What do you guys think?
If it were me, I would tighten the lobe separation for more midrange punch. Something like 110LSA installed at 106.
You will need to check piston to valve clearance.
I might have to do a custom grind then. I did not see any with 110lsa with those specs. Will the vic jr kill my cruise speed with the intake making its power at over 3000 rpm. Will a spacer on the carb help.
Tough question. That is pretty good sized cam. I don't think the vic jr. will do anything that the cam didn't already accomplish.
I've been reading cam posts for the last few weeks trying to figure out what is reasonable for a light weight street car. Hard to get a definitive answer cause people all look at it differently. Like one guy said, it is sort of like arguing whether a chick is hot. Depends on what you are use to I guess.
Old School Heavy
Do you think it will be that bad? ZONES89RS is running a TRex cam so I did a search and found an old-old thread about it. If I got the right one, the TRex cam is 242/248 duration, 0.608/0.612 lift on a 110° LSA. So big *** cam. The thread started out with people bashing how badly they thought that cam would work on the street (it was a really old thread, not many guys were running it yet). But by the end of the thread all the naysayers had pretty much stopped posting once more and more guys posted their actual results. The ¼ mile and dyno results were massively impressive, but the EFI guys using them claimed good low end manners and not bad MPG.
A large cam is going to be a lot more liveable with an automatic transmission and higher stall torque converter, than it might be in a manual transmission equipped vehical. So a lot of it depends on transmission, rear gear, and weight of vehical. Eric L
Old School Heavy
It is also important to note that Fuel Injection fuel delivery and tuning techniques can help tame a big camshaft. I think the OP is going carbureted. And, before anyone claims that a well tuned carburetor can do anything fuel injection can; not in this case. The low RPM reversion in the intake manifold caused by long period cam durations causes havoc with the fuel metering in a carburetor. This is worse in open plenum intakes. So, fuel injection has an advantage in taming a large camshaft.
The OPs combination looks excellent to me. Now rather or not it is correct for his desired outcome may be another story. I think he needs to spell out the exact driving and performance characteristics that are most important to him. The answer will be in that conversation.
My last cam in my 6.0L stroker was 239/243 - .651/.654 - 109LSA installed straight up. It was installed in a bigger engine, but it was a very tame sounding camshaft. As a matter of fact it was probably the smallest cam I had ever run in my Camaro which sees a lot of street miles. I had driven it round trip to work many times; 60 miles each way in the heat of summer and the dead cold of winter. An earlier daily driver SBC set-up was a 388cid with a 5spd and 3.73 gears (equiv. to more like a 4.56 rear where I had a low first and through the traps in 4th). The larger of the cams I had in it was a 260/266 - .630/.630 - 110LSA+4. It was a solid roller but was far more radical and I still drove it all over the place.
The cam you mentioned is small. But, if your set-up surges at low speed just put a lower rear end gear in it and have fun.
Thanks for all of the input. I think with the 3.73 rear gear I may have a little bucking but that is part of the experience. I am going to stay with 231/239 duration cam.
