Mechanical for vacuum secondaries? 5 speed, 5.3L, 2900lbs
Here's my plan:
The motor:
5.3L L33 LS
TSP 224r cam (I think the 228r would be over kill on the 5.3L)
Edelbrock performer RPM intake
The car:
2900-3000lbs
5 speed Manual tranny
3.89 FDR
mainly street driven although will see up to 10 lapping events/track days (NOT drag racing)
I've been reading VS are better for street driven, heavy, automatic cars, and MS are better for lightweight, manual trans, WOT performance/race cars.
I assume I'm in the lighter category, but will mainly be street driven.
What do I choose?
750VS
or
650DP?
Thanks for any input
The motor:
5.3L L33 LS
The car:
2900-3000lbs
3.89 FDR
What do I choose?
750VS
or
650DP?
sorry, final drive is 3.89
Also what fuel pump is everyone running on a set-up like this? Like what psi/gph? (im gathering 7psi/110gph is very popular)
Holley's web site has an interactive carb selection guide. The say a mechanical secondary carb is OK for manual transmission cars that are under 3100# and having a 3.73 or lower rear gear.
If you run a return style fuel system and 3/8 lines then a 90 gph pump or larger should be more than sufficient.
