Get stock starter/alternator to work without the computer?
Working on a 72 nova LS2 carb swap, Im just curious if I can get the stock alternator and starter to operate properly without the Computer? Or do I need special setups of the both? 1 wire, different starter?
Thanks
Thanks
Use the same wires you used for you starter before to the new one, nothing changes.
Alternator, if its an f body alternator, you need to put a resistor on a B+ wire to i think the "B" Terminal. Might want to make sure which terminal because im not 100% positive which one.
The wire on the back of the alternator should be the same as your original alternator of the car.
12v to the rear lug on the alternator..... idiot light or 470ohm resistor to terminal B on the pin connector
this thread helped me a lot ...
https://ls1tech.com/forums/conversio...aq-thread.html
