Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
my combo
Old Jul 18, 2011 | 07:27 AM
70shortwide's Avatar
Default my combo
been on here for a while just observing but havent posted much. im putting a ls6 in my pickup and was wanting yalls opinion on my combo since this is my first ls motor.
2004 ls6
TEA stage 2.5 ls6 heads
eps 230/238 .600/.603 112+3
victor jr. intake
1150 domimator (i know its too big but its wat i got layin around)
6010 box
turbo 400
3800 stall (i think i need bigger)
9" rear with 4.11
200 shot
im hopin for mid to high 11's on motor and high 10's on n2o
truck weighed 3950 with big block and me in it
so tell me wat yall think?
thanks
Old Jul 18, 2011 | 09:58 AM
slp1300's Avatar
I think you have a good combo just the carb it is too big, maybe a 750 or 850 would work better, my truck weights a lillte less than yours like 3700lbs with a lq9 camed, 750dp, th400, 3000stall, 3.73 gears and it is doing 12.90 in the quarter mile
Old Jul 18, 2011 | 10:34 AM
well the truck itself weighed 3750 so im hopin to get down to 36?? and im tryin to find a 950 around here to trade cause i aint got the extra cash to buy another carb. it deffinitly wont be starvin lmao!!!
Old Jul 18, 2011 | 11:46 AM
Pop N Wood's Avatar
That thing should move some air. With those heads and cam you will definitely need bigger than a 750 carb. the 1150 may be more of a challange to tune, but it's not like you are looking for street manners.
I assume you will have some long tubes and big diameter exhaust to back it up?
Do you need to port match the intake to the heads?
Old Jul 18, 2011 | 11:59 AM
im gonna run 1 3/4 primaries with 2.5 collector and i already have 3" duals on the truck. im not to worried bout port matching.
Old Jul 18, 2011 | 03:32 PM
speedtigger's Avatar
Old School Heavy
Everything looks delicious except for that carb. I would not even bolt it on. It would take a real carb guru to make that run without fouling a set of plugs per day.
Old Jul 18, 2011 | 04:26 PM
MTC_75vette's Avatar
I agree I would not even attempt to run that carb with this set up way to big. If you already had the cam I am sure it will work fine but if you have not purchased a cam yet i would get something with a tighter lsa the single plane manifolds like 108-110 best. Best bet would be a custom cam by Pat G.
Old Jul 18, 2011 | 05:14 PM
well i already have the cam. its wat geoff at eps recommended. its actually installed at 109 but ground to 112. it should love the nitrous hehe. as far as the carb goes i will just jet it down. ive ran carbs to big for motors before and even tho there not ideal i think i can get this to work.
Old Jul 18, 2011 | 05:22 PM
anybody got a 950 they wanna trade?
Old Jul 18, 2011 | 05:56 PM
Old School Heavy
I am thinking it is the idle calibration that will be the killer.
Old Jul 18, 2011 | 06:15 PM
a dominator has a 4 corner idleing and lots of adjustment to fine tune it. if i could find a 950hp i would trade in a heartbeat but i gotta work with what i got.
Old Jul 18, 2011 | 06:35 PM
Old School Heavy
The screws can only do so much. At some point you have to change the orifices.
Old Jul 18, 2011 | 07:47 PM
3pedals's Avatar
holley 950 is TOO SMALL, its actually a 750cfm carb. The 1150 dominator is big, but if thats what you have and you dont want to spend money, it will work. As mensioned, it will require some tinkering to get the idle and transitions figured out, but it can be done. I run an 850 mighty demon on mine which flows closer to 1000 cfm in reality
Old Jul 19, 2011 | 08:19 AM
ok so besides the carb what do yall think?
Old Jul 19, 2011 | 02:40 PM
3pedals's Avatar
should work pretty good, converter will be good for leaving with the juice on and if you can get it to hook, but a little tight for n/a. If you have all the parts already, then bolt it together and let'er rip, then post your results
Old Jul 19, 2011 | 02:43 PM
hookin wont be a problem. im gonna try to start it next weekend. just tryin tp get all little parts rounded up. then i put sheet metal back on truck and giver hell!!!
Old Apr 25, 2012 | 04:10 PM
well i thought i would post on this again. i finally started it last night. i got a 950hp for it and a 4000 stall. i put the number 5 chip in it just to start it. it turned over about 3 times and busted off and sat there and idled like it has been running for years. i need to finish up some small stuff on truck then its time to see what she will do!!! this thing would have never ran if it wasn't for all the info on this website.
