gen IV whith carb.
Hi ,i need information,i have 2010 6.0L truck engine with vvt. i install the engine in my gen 3 camaro.for the MSD ingnition the cam sensor is importent?or the MSD use only crank sensor?because i whant,remove the front cover whit vvt and cam sensor for istall the old timmig cover. Thank's
excuse my english i come from Montréal Québec!!![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Dominic
Dominic
Yes, the box needs the cam sensor. Why can't you keep that when you get rid of the VVT?
Was surfing the MSD site and found this today
So I guess if you are a betting man than you don't have to have a cam sensor
Originally Posted by http://www.msdignition.com/StarterApps/Wiki/Dynamic.aspx?id=14461&__taxonomyid=2235
If the motor is back firing through the carburetor or exhaust, there is a good possibility that the problem is related to the cam sensor. The LSx motor has a 50% chance of starting each time you crank on it even if the cam sensor has failed.
tank's for your information! if i instal the timing cover whitout vvt,i need to change the timing chain?or j ust remouve the clutch on the sproket?
i did same swap.. need cam cover.. can keep the cam sensor..same part number.. . pretty sure of it.. and need a cam sprocket ,with 4x signal.. just buy it for an 2010 ls3. is everything u need.. or ls2 cover.. but watch out for ls2 cam gear, one year they still had the 1x siganl on sprocket.. then swapped over to the 4X.. i bought the wrong one..
These are the cam gears I got and the front cover to convert my ly6. Have not started it yet due to a car accident (was rear ended) and could not work in the garage.
Here is the pic. I got both a single bolt and 3 bolt cam both have the same pattern/portion of raised metal and it also matches what is on the vvt cam phaser on my 2009 ly6
http://users.xplornet.com/~bitterman/parts1.JPG
Regards,
Bruce
Regards,
Bruce
Hi zones89rs,do you have picture at your cars ,a have many question for you. beacause my car is 82 camaro and i want to instal the LS engine.
the engine is 2010 6.0l .is truck engine
Tanks
Dom.
Tanks
Dom.
Here is what the 4X cam gear looks like. I think you can get them with a single bolt type mounting, but not 100% sure on that. With the MSD 6012 box, you have to use the 4X gear.
http://www.lingenfelter.com/mm5/merc...Category_Code=
