Need some help!
Thank you for you time
You might start by reading through some of the build threads. Best way to get go fast ideas.
To go carb all you need is an intake, carb and MSD ignition box. The MSD box has a complete stand alone harness that makes the wiring super simple.
You will also need either a carb specific fuel pump or a regulator that lets you turn your FI pump down to 6 psi at the carb.
There are obviously a lot of small things like linkage, an air cleaner, fuel filter etc, but those are the big items.
How you will get sufficient hook clearance is different question.
If you completely take out the PCM then the only gauge in the cluster that will work is the volt gauge. You'll have to run a new electric fan or rewire the factory setup so they work. I can go on but if you have specific questions shoot me a PM
