lq4/ls3 heads g6x3 cam.holley 750dp hp good enough??
Sup fellas im doing a swap soon and need some help with a couple things first of ill start with the set up
Lq4 motor
ls3 heads .30 milled what should my cc be??
Vic jr.
holley 750 hp is this good enough?? Or should i get a 850hp
lg g6x3
High valume oil pump
Ls2 chain and hd sprokets
trunion upgrade
viper T56
Textrilla clutch
3.55's
3500 lbs
Thats what i have so far except intake
Things i need to get
Msd 6010
675. Valve springs
Push rods
Vic jr intake
Arp rod bolts what u guys think??
Arp head bolts
fuelp pump and filter's i need help with this
i need part number for auto meter oil and water sending unit ,fitting's to lsx block.
Thats as far i come with the built,i know im gonna need to flycut the piston's for insurance reasons.Any help with what im missing or should do would be appreciated.old school rocks!!!
Lq4 motor
Vic jr.
lg g6x3
trunion upgrade
viper T56
Textrilla clutch
3.55's
3500 lbs
Msd 6010
675. Valve springs
Push rods
Vic jr intake
Arp head bolts
I think everything you listed sounds good. I don't know about the high volume oil pump though. I think most stick with ported stock or high pressure/stock volume pumps...but I'm not too up on that stuff.
following this, cause im doing this swap into my 70 camaro. With that cam in a stock ls3 the PTV is very close, might want to check if if milling the heads. im fly cutting my pistons, or might order new pistons for my build, doing a stock ls2 bottom end.
but the lq4 pistons might leave u enough room, not sure tho
I'm pretty much doing the same build. I plan on using the street/strip Aeromotive pump and filter. I've ran it on 2 previous cars and it's never given me a problem with either set up. One car I ran it on was 650hp n/a. Also ran it with the 100micron filter.
Don't waist your money on high $ regulators, use the Holley 30$ ones. Me and many people I know have for years without issue.
http://www.jegs.com/i/Aeromotive/027/11203/10002/-1
Regulator
http://www.jegs.com/i/Holley/510/12-803/10002/-1
ARP rod bolts and heads studs are a great choice too. Escpecially the rod bolts!
Regulator
Lq4 has dished pistons. 7 cc actually, Dont know what the specs of the cam are and with the size of the valves in those heads ptv clearence should be checked but it will be much better then flat top pistons allow.
Im thinking you will have a low compression set up though
Heads are milled .30 so should be 10:5 or around there,ptv im gonna flycut the pistons for insurance reasons.as for the cam 24x/23x 64x/61x 111lsa from what i hear.but i have made my mind up and selling the 750dp hp not doing the carb thing anymore
