Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
first time out with lq4 powered mustang
Old 10-30-2011, 08:44 PM
11 Second Truck Club
bluecajun5.3's Avatar
ran it with the 28x10's today and my gearing is good now, crossing at 7000. went a new best 10.35@130 1.44 60'. kept adding jet to the carb and it's still eating it. got 89 front 90 rear, timing at 29. next time going to keep adding jet and/or might try out a 950 carb.
Old 11-01-2011, 05:01 PM
LXinMS's Avatar
What stall? Hopefully I'm not a jackass and missed it...historically, that's been the case.
Old 11-01-2011, 05:10 PM
LXinMS's Avatar
Also, suspension mods?
Old 11-01-2011, 08:00 PM
topbrent's Avatar
Awesome progress!
Are you keeping track of the DA when you make your runs?
Old 11-01-2011, 11:50 PM
LQ4 TECH's Avatar
Not to be off topic but im building an 04 LQ4 also and understand you put the ARP rod bolts in your setup, which i have ordered the 2000 series, and keep thinking about everyone saying you have to resize the rods when you go with ARP, how did you go about installing your rod bolts? thanks..
Old 11-02-2011, 08:33 AM
bigchief52780's Avatar
i used arp rod bolts and didn't resize my rods. i have been running my car since the beginning of the year. i drive it daily and have raced a couple times.
10" tci 3800-4000
tubular a-arms and k-member up front, coil overs up front, strange shocks all around, south side bars in rear.
Originally Posted by topbrent
Awesome progress!
Thanks man! yes DA was 100 first time out and was 600 on these last runs.
I used the 8740 ones. I removed 1 bolt and sleeve at a time. Install new bolt and be sure to lube threads and underneath the head of the bolt. torque to 40ft lbs 3 times.
ex...
1 torque to 40, break torque
2 torque to 40, break torque
3 torque to 40
Old 11-03-2011, 04:49 AM
Killer5.3's Avatar
Have you tried the preset chips in the MSD? Carbed Ls motors usually like more timing. My carbed 5.3 liked 35 degrees total. I ran the most aggressive chip , I think it was #6 but it has been a while. I tried tweeking the timing curve with the handheld box and it always ran better with their preset and 35 total. I would pull timing out for the nitrous using the handheld. Also Pro Systems carbs are great. I would call Patrick @ pro systems and fill out the online tech form. Send that carb into him and let him reflow it based on your combo. He is real reasonable on $$. You will not be disappointed with the results. It will be just about spot on out of the box when you get it back. Good luck and nice ride sir.
Old 11-03-2011, 03:14 PM
LQ4 TECH's Avatar
Thanks guys, I've heard both sides of the story on how you should have your rods resized, and now i know, i have bought a set of ARP's, and i appreciate the advice!
Old 11-03-2011, 08:58 PM
Z284thgen's Avatar
damn i gotta get rid of these 853's
Old 11-16-2011, 08:09 PM
streetknight2's Avatar
Subscribed
Old 11-16-2011, 09:06 PM
  #32
thank you!
i started at 32 and been working my way down and adding jet to see if i can get some more color in the plug. after the new year i'll probably send off the carb to them so they can tweak it to my combo.
Old 12-07-2011, 04:23 PM
  #33
richard david's Avatar
I have almost the exact motor setup you have in my mustang and I just changed over from the edelbrock box to the 6010 and I was curious on how you set your timing curve.
Old 12-10-2011, 06:42 PM
  #34
i would have to pull it up and take a look.
Quick Reply: first time out with lq4 powered mustang
