Hood clearance...SBC vs LS
Im still up in the air about going EFI or carb. I have fit a sbc with a rpm air gap and drop base filter under the stock hood(240z). Is the LS with a carb any taller with the carbed set up over the SBC? It was pointed out in another thread that the GMPP single plane was 1" lower than the Vic Jr so most likley will end up going that route. Any and all info would be great!
Anyway, in order to get it to fit with a 14" filter, I modified an air cleaner assembly from a 403 Olds 2nd gen TA (has an offset carb hole, BTW - useful for shifting the assembly around for better alignment with things). Instead of using the band to attach the upper and lower halfs, i modded the upper half so it would be a slip fit into the lower half. That took about 1/2" out of the total height of the assembly. The whole deal now clears my factory hood by 1/8", where it didn't even come close before.
The Original Equipment air cleaner, on the original 305 SBC, cleared the hood by about 3/4" and used rubber seals to make a snug fit. It also used a smaller diameter 12" air cleaner element.
