Carb and timing on LQ9
Hey guys. I have an 1985 Oldsmobile cutlass with a '02 lq9. Stock 317's which I have shaved and a good valve job. It has a Texas Speed Tsunami can 235/240, .649/.609 lift, 111 LSA. 10.2 to 1 compression. Th350 with 3500-3800 stall, 1 3/4 LT headers and 4.10 gears. Should be 3400lbs. OK I'm using the MSD 6010 and I wanted to timing suggestions. I also have a Holley 750DP and i wanted some basline Carb tips as in jet sizes and accelerator pump diaphragms? Thanks guys.
I was just looking at the thread where everyone was talking about their timing and heres what I came up with.
Timing: 15 degrees at 0, 28@ 750, and 34 degrees at 2000 rpm on up. What you think?
For the carb, should I put the 50cc shot in front and 30cc in the back or leave it 30cc front/50cc rear?
id go with the 30cc pump in front and rear to start, if it hesitates you may need to go up in shooter size. I still run the 30cc front and rear in my 850, but I run a 40 shooter in front and 35 in rear. If it still hesitates with a 40 shooter then you could try the 50cc pump in front.
And i agree with speedtiger - start off on the safe side with timing - 28-30ish, if the plugs are not showing heat then add a bit......
Old School Heavy
A wide band is a great tool for ball parking until you can track or dyno tune it. Holley factory jetting should not be too far off. Mine ended up needing a lot more jet, but others did not. With all the different potential combinations, there is really no way to know without testing.
Not sure if it will help you or not, mine is an 02 LS-1 w/ TEA heads and a 230/230 612/591 lift 111+2. My plugs look perfect and I have 78s in the front and 88s in the back, it's a Holley 750 DP also. I went up one squirter size in the primary too.
Old School Heavy
Hey Joye, I think it depends on the list # but if I remember correctly, mine had a 27 in the front and a 31 in the rear. I moved the 31 from the rear to the front, and put a 35 in the rear. The plugs look great and throttle response is really good.
Old School Heavy
If the carburetor is used and new to this build I would suggest that you return the carb to the factory jetting and calibration listed in the Holley document that I listed above and then tune from there. To tune accurately you will need one of these scenarios:
Even if you go to the track or the dyno for a tune, you should still get an A/F meter to set your cruise A/F ratio. Most of the double pumpers have a cruise A/F ratio of about 12.5:1. It needs to be 14.5:1 for clean plugs and good fuel economy.
- a wide band a/f meter.
- A dyno tune.
- A trip to the drag strip to tune for fastest MPH and/or the ability to read plugs properly.
