Super Chevy april issue
Has anyone read the article on the Holley dual quad intake vs vic jr intake? Dual quad took bottom end honors by 50lb. ft torque. It stayed right with the single plane with 1 hp difference on the high end. Fairly impressive.
2-4's or 3-2's work great... until you need to tune... but drivability<sp> suffers atleast as I heard...Never had a need for 2-4's or 3-2's muddin'
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I have no clue as to drivability. The extra grunt may be due to the dual plane design and better fuel distribution. The carbs I am sure can be dialed in a little better but they had good a/f on wot.
Old School Heavy
Also, you can effectively port the Victor pretty easily. It is nearly impossible to do much more than a port match on the Performer. I have not seen the dual 4 intake in person, but I suspect it would be the same scenario.
Oh, and tuning those Carter style carbs suck.
The motor was a bit of a bastard, a 5.3L stroked to a 383 with 215 heads. The thing made 527 HP at 6000 RPM. They didn't spin it any higher than that. The dual quad was also a dual plane. Probably weighted and extra 10 pounds with all that metal. Interestingly I couldn't find the cam specs in the article.
The two systems were dead equal above 5000 RPM. Have to wonder if the heads were limiting the airflow and not the intakes. Put those two intakes on on a motor with a 4 inch bore and spin them to +7K and see what happens then.
Comp LSR 281LR HR13 #54-459-11
.617/.624 231/239 113+4
I believe they mentioned that Holley makes the same manifold for the L92 type heads and that it performed the same. A buddy swiped my copy and hasn't returned it but if you'll reread I believe you'll find it.
Jarhead
Jarhead
Old School Heavy
Yeah yeah. I was thinking of the Edelbrock set up. I guess it would make sense that Holley would design their intake for Holleys eh?
I actually drove a twin 600 Holley/Offenhauser low rise equipped 65 440 Coronet for a guy for 1 season in 1990. The set up worked flawlessly and was actually faster than his single 850 set up on that car.
