What will a stock LQ9 do? Here's what.
#43
I'm in Volusia - takes about an hour to get down to Speedworld. You guys have an eighth mile track in Lakeland, right?
Apparently there is a new 1/8 mile track right near the Orlando Airport, mostly imports there?
#46
yeah the 8th mile is still a little rough but they are cleaning it up a bit. Actually seen some decent cars recently. Cool thing about it is you get to make as many runs as you want basically.....
#50
I'm going to save up and get a cam and springs for it this summer.
I'll probably not do a stall for a while, I had such a hard time getting the exhaust in and out last time I had the tranny out. When got the exhaust system, I told the guy at the shop "Use some flanges and bolts somewhere so I can get it out later." He did, but the joints are not on a parallel portion so picture me laying on my garage floor using a hammer and 3 cans of PB blaster!!!
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
#56
If you are on a serious budget, I would go with an 8.5 10 bolt. just weld the axle tubes(use hi nickle rods or wire) a set of summit axles, factory style limited slip( make sure it is good. they dont make rebuilt parts YET) and gear it for your intentions and you are ready to go. Should hold 500+HP at the wheels with no problem and they free up a little HP to the wheels. Just my .02.
By the way GREAT NUMBERS!!!!!
