Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Ly6?
Old Apr 1, 2012 | 09:21 PM
dmracing's Avatar
Default Ly6?
I just bought a 08 LY6 and am installing it in a 93 Mustang Coupe. I will be removing the VVT. Does anyone whats the biggest cam you cam run without getting into P to V clearance. Im looking to run in the 10's on pump gas on motor alone if possible.
Old Apr 1, 2012 | 10:28 PM
ZONES89RS's Avatar
In-Zane Moderator
I am not sure what pistons are on those, but the dish pieces help on the lq4s.
Old Apr 1, 2012 | 11:29 PM
NemeSS's Avatar
They have a dish and a deep vr. on the intake side.
actually the piston has 2valve relieves. But its only functional on the intake valve.
still gonna have to check ptv on exhaust side.
If cut one for exhaust, will end up with 3 valve relieves and dish on each piston
Old Apr 1, 2012 | 11:45 PM
3pedals's Avatar
I have an LY6, the pistons are dished, and have exhaust valve reliefs, and NO intake reliefs. Here is a pic of my pistons with very small flycuts for the intake valves
I ran a 227/235 @ .050", 114 +4 with lots of PtoV clearence, I would think a 231-239 on a 114 would fit, but as you tighten up the LSA things start to get closer.
Old Apr 2, 2012 | 12:23 AM
ZONES89RS's Avatar
In-Zane Moderator
Ah, interesting.
Old Apr 2, 2012 | 01:26 AM
NemeSS's Avatar
Pedals is correct. I was thinking exhaust. but typed intake. Long day i guess. I meant exhausts. Istead of intake.
Was out in the heat too long today polishing my new tt2's. And had a few
Old Apr 2, 2012 | 04:24 AM
dmracing's Avatar
How fast did you go with that camshaft, if you dont mind me asking, and what was your weight?
Old Apr 2, 2012 | 09:36 AM
3pedals's Avatar
11.39 @ 120, @ 3425 race weight. this is using a stick shift. an auto would ET 2-3 tenths quicker if the converter was right.
Old Apr 2, 2012 | 09:48 AM
dmracing's Avatar
3pedals, what was the lift on that cam. Did it sound pretty healthy. Also to get rid of the VVT. All I have to do is change out the cam gear and timing cover, correct? My car should weigh about 3000. This might get me were I want to be.
Old Apr 2, 2012 | 10:39 AM
3pedals's Avatar
the cam was comp 227/.612, 235/.624, 114+4. The cam sounded great, and I guarantee it will run a high 10 in a 3000lb car. needs GOOD valvesprings. Comp has a shelf grind that was the same but ground on a 113LSA
There are better cams out there for sure, and it will depend on if you are running carb intake or not and how much low end you are willing to give up.
I saw you post about this elsewhere, not sure if you are carbed or not...
VVT removal , yes- 4x top cam gear + retaining bolts, ls2 front cover , and your new cam.
Barrett
Old Apr 2, 2012 | 10:44 AM
dmracing's Avatar
Carb, edelbrock 28457 intake. What cam would you run?
Old Apr 2, 2012 | 10:46 AM
dmracing's Avatar
The carb id a 4150 Quick Fuel 4150
Old Apr 2, 2012 | 02:18 PM
GC99TA's Avatar
I know I already answered all of this for you via PM last week, but since you're asking about it again, I'll post it in here for the benefit of others that may be looking for the same information (ie. what cams MAY fit in an LY6 and how to delete VVT). Maybe this will help someone when they search one day.
Originally Posted by GC99TA
My cam is a custom grind that is ground on Comp HUC lobes. It was ground for a single plain intake (carb application). It's a 231/239 110LSA+1. I didn't have to flycut for this cam to fit, but it's in on a 111ICL (one degree retarded from straight up) rather than a 109 as it was intended to be. This two degree discrepancy between where the cam went in and where it was supposed to be was probably just due to a varience in my timing set. But if it would have gone in on a 109ICL I have a feeling it would have been a little too tight on the intake side and may have required a slight flycut to be safe. As it's installed right now, it's got around .090 on the intake and plenty more on the exhaust. This is pleny of room (I like .080 intake and .100 exh), but if I were to advance it two more degrees and put it where it's supposed to be, I think it would be too tight (maybe as tight as .050 on the intake).
If you get a cam like mine, just plan to check your piston to valve clearance. If you don't want to fly cut, just buy an adjustable timing set (if needed) and install it on a 111 ICL like mine and you'll be good to go. Assuming you've got a decently loose converter, I'm sure you'll have no problems running high 10's in a fox body with this combo. My car weighs almost 3500 with me in it and it's gone 11.50s in pretty bad DA. Good luck!
To ditch the VVT you just need to replace the cam phaser/cam sprocket with one from a late LS2 or LS7 (pn 12586481). It will have the 4x reluctor and three bolt holes for a standard 3 bolt cam. Then you'll need an LS2 front cover, which should be pn 12600325. Thats basically all that's required. VVT motors use standard lifter so there's no worry there. VVT motors don't take as much to convert as a DoD motor. I hope this helps.
Old Apr 2, 2012 | 06:42 PM
dmracing's Avatar
I wasnt doubting what you said just trying to get more opinions on camshafts. I still think Im going to end up ordering the one you have.
Old Apr 2, 2012 | 07:44 PM
GC99TA's Avatar
No sweat man. That's not what I meant to imply, even if it came out that way. And even if you were second guessing what I already told you.....I couldn't blame you for that. I generally don't base my decisions on one unknown person's input either.
I guess what I should have said was "now that you're asking about it publically" rather than "since you're asking about it again". My intended point was that I saw this thread as an opportunity to share publically with others what I had already shared with you privately. I never mind answering questions via PMs and I always will, but it benefits more of the "community" when these questions are asked and answered by several people publically.
Between the info that Barrett provided above and what I've now provided about the experiences with my cam and the VVT delete part numbers, someone in the future should be able to search and get a pretty good idea of what works (that is, if you trust the two guys with sig pics of LY6 camaro's lifting the front wheels......LOL).
As always, best of luck and definately let us know how it works out.....no matter what you choose. That's how we all learn and continue to develop our own combinations.
Old Apr 4, 2012 | 10:15 PM
dmracing's Avatar
I need a MSD 6012 correct? What did you guys use to clean the engine that didnt hurt the aluminum.
Old Apr 4, 2012 | 10:25 PM
GC99TA's Avatar
Yes, you need a 6012 for your LY6. I mostly cleaned my motor with brake parts cleaner and wire brushes, but mine wasn't too dirty with less than 3000 miles on it. Things like the water pump and other removable aluminum items (like alternator brackets and such) were ran through the dish washer after they were mostly clean with brake parts cleaner. I use brake parts cleaner to clean a lot of parts because it cuts grease and other grime very, very well and never leaves any type of residue behind. I'm sure others will have more ideas for you though.
Old Apr 5, 2012 | 01:03 AM
3pedals's Avatar
THE DISHWASHER!!!!!!, you have a very understanding wife!!! Lol
Old Apr 5, 2012 | 10:18 PM
GC99TA's Avatar
Yeah......she usually just shakes her head and walks away .
Old Apr 6, 2012 | 07:46 PM
dmracing's Avatar
Alright, I think Im getting this one.
227/235 duration
.614/.625 lift
109/117 lobe centerline
113 LSA
I plan to use a little nitrous, so I figure the 113 will help.
Also how did you guy mount the alternator?
