Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Anyone have a msd box go bad?
Old 07-15-2012, 05:49 PM
In-Zane Moderator
ZONES89RS's Avatar
Where is it grounded? If it is to a painted surface, that can do it.
Old 07-16-2012, 12:18 AM
Thumpn's Avatar
Originally Posted by Pop N Wood
Should be a simple matter to test the coils individually using nothing more than 12V power and a 9V battery as a trigger signal.
Try a youtube search, I'll be a dollar someone has posted a video.
Should be hellaciously cheaper than replacing the full set of coils.
I have done a tube search and all the off motor tests have been done with a frequency generator and Osc scope, nothing as simple *** giving power.
It is grounded directly to the battery.
Old 07-16-2012, 06:44 PM
In-Zane Moderator
ZONES89RS's Avatar
Why size wire?
Old 07-16-2012, 08:44 PM
Pop N Wood's Avatar
For an LS2 coil hook terminals A&B to a ground and +12V from the battery to terminals D. Then touch a 9V battery across C+ and ground. That ought to fire the coil.
Probably not a 100% test, the coils could go weak when hit at a high rate, but this will definitely find a dead bad one.
Old 07-17-2012, 12:47 AM
Thumpn's Avatar
Why size wire?
the wire size from my MSD box to battery is a 10awg wire and the run is about 6 ft.
i finally figured a way to test my coils. here is a video.
Old 07-17-2012, 06:40 AM
In-Zane Moderator
ZONES89RS's Avatar
I ground mine to the block.
Old 07-17-2012, 08:28 AM
Thumpn's Avatar
my msd block is inside on my dash.
Old 07-18-2012, 10:09 PM
TD21's Avatar
get a big block Kevin......then you can get out of your own way on the river. lol
Old 07-18-2012, 10:22 PM
BLK95-Z's Avatar
If its carbed why not just run a distributor?
Im considering carbing my race car
Old 07-18-2012, 11:12 PM
sandeggo's Avatar
Haha the goal will be to run with you if not pass ya
Old 07-19-2012, 06:26 PM
TD21's Avatar
Wont happen, its getting a freshen up.....you can run with the new boat all day...if it will run haha
Old 07-31-2012, 08:58 PM
  #32
sandeggo's Avatar
Just because I hate to let threads die without solution. The problem with all the misfires ended up being a faulty crank position sensor.
Old 08-01-2012, 12:39 AM
  #33
pairof69s's Avatar
nice to hear ya got it straight....
Old 11-30-2012, 10:42 AM
  #34
sandeggo's Avatar
guess I should update that it in fact was not the sensor but a broken piston.
Old 11-30-2012, 02:00 PM
  #35
NemeSS's Avatar
yea, that usually is not so great for power making.
Old 11-30-2012, 02:13 PM
  #36
sandeggo's Avatar
Haha but it still started and ran fine for months. It was just a V7
Old 11-30-2012, 07:40 PM
  #37
In-Zane Moderator
ZONES89RS's Avatar
Well, how did it do? Lol
Old 11-30-2012, 07:49 PM
  #38
sandeggo's Avatar
Surprisingly well. It was down on rpm and you could tell something wasn't right but I drove the snot out of it from may through October like that. Still did over 60 mph
Quick Reply: Anyone have a msd box go bad?
