Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Deliver Me From Temptation - N2O
Old 08-16-2012, 05:23 PM
Old School Heavy
speedtigger's Avatar
Originally Posted by 2lucke4u
i ran 2 gallons 93 + 3 gallons 116 race in my dedicated nos cell,about 106 octane,pulled 6 on the timing,windowed 35-6500 with the hyfire box,no problems for five years and LOTS of bottles thru it,good luck,,small steps to big gains,
Charles
Are you running stock pistons? How big of a shot?
Old 08-16-2012, 05:44 PM
2lucke4u's Avatar
forged pistons 9.5 comp,the shot added 134rwhp on the dyno,guessing the 150 shot jets,hard to tell when you don't follow the instructions and start to square up the jets,i would give you exact numbers but the car is now gone and working on the lq4 68 firebird,i ran very conservative on the bottle and enjoyed the gains without pain,my buddies running two, three, and four stage systems were fixing their cars every other run,too expensive for me,will help pit for a four stage 69 camaro that runs 7.0s in the quarter in a couple of weeks,hope to get some video,will post if so,
Old 08-16-2012, 09:27 PM
The stunningman's Avatar
Originally Posted by speedtigger
I read in another thread that NGK Stock# 3346 ( Br7ef ) are the plugs to run at about .030". Anyone have any input on that? I also read guys are pulling about 6 degrees of timing for a 150 shot. Thoughts? What fuel are you guys running?
I'm running 103 autolites at .035 with zero problems. I pull 8 degrees out on 150 shot. My times don't seem to change when adding more timing but I can't say for sure I stay hooked, my 60 goes up 1.44 instead of 1.39 and the mph doesn't. I run 50/50 mix on race fuel and premium. I have pulled a lot of plugs and cut them up with no specking or anything so I'm happy. I have wondered about pulling less timing for race fuel because we all know that the NOS timing pull rule is usually for premium ... not the 110 race fuel or mix. However I'm not interested in testing the boundaries to much on my own vehicle.
Old 08-16-2012, 10:04 PM
3pedals's Avatar
Deliver me from temptation
Hahaha, lol
Kinda looks like the boys are delivering you directly to temptation!
I'm tempted too, but I don't think I'll dance with this devil......yet, lol
Old 08-17-2012, 07:41 AM
Old School Heavy
Thanx for sharing that. I am not interested in pushing the limits either. I want to be as safe as possible. Are you stock shortblock?
Old 08-17-2012, 07:43 AM
Old School Heavy
Originally Posted by 3pedals
Hahaha, lol
If I was 10s N/A, I would most likely not bother with the nitrous. Your car is a beast.
Old 08-17-2012, 12:29 PM
Yep 2009 LY6 stock pistons and rods.
Old 08-29-2012, 08:26 PM
Old School Heavy
Got a pile of goodies from the UPS guy. Some Earl's fittings, an additional fuel pressure gauge, bottle heater, bottle blanket, assorted jet kit and a blow down tube.
Old 08-29-2012, 08:38 PM
3pedals's Avatar
time to DANCE
Old 08-29-2012, 08:55 PM
Old School Heavy
What kit are you running? What jets?
Old 08-29-2012, 10:51 PM
Pwebbz28's Avatar
Isn't a lot of that Av gas oxigenated?
It's not that. It has CRAZY amount of lead for vehicles in it. Even though its called 100LL (low lead) that means low by aviation standards. It also is lighter than regular gas and therefor must be run richer. I ran it in my solid roller 414 for a couple tanks and didn't like what it did to my oil and plugs.
Old 08-29-2012, 11:58 PM
  #32
I'm running a sniper kit. Its only adjustable to 150. I'm running the 150 ones, I don't recall the sizes right off, I will edit tomorrow.
The line on the sniper and solenoids are smaller than yours. Also I tried a High flow valve bottle, a buddy of mine had and my times didn't change at all. I'm just letting you know that as a "In my experience thing"... I'm glad I didn't have to buy a high flow valve or high flow bottle trying to make it go faster. However, all that could be just because of the limits of the lines solenoids etc. It could make a diffence on a cheater system. So if you get a chance to swap them out let me know what you find. I have 50+ passes on mine on the 150 shot. Pulled the heads recently making some mods before dropping the engine in the Fairmont I am building. Everything looked great inside.
Old 08-30-2012, 08:07 AM
  #33
Old School Heavy
The cheater instructions show to run the jets "square", but most of the nitrous experts on Yellow Bullet including Monte from NOS said to run an 8 to 10 spread with a larger nitrous jet than fuel. I just wanted to know what your jet spread was and what your plugs look like after a pass.
Old 08-30-2012, 05:39 PM
  #34
Old School Heavy
A mock up for the fuel side:
Old 08-30-2012, 07:05 PM
  #35
Doug G's Avatar
I think they recommend squared due to fuel pressure, timing, set-up, ect, variances they can't control and a little fat is a good thing sometimes. If you're off on the tune...it's better to be on that side of things....too lean and you'll be draining aluminum out of the oil pan.
Old 09-01-2012, 07:51 PM
  #36
63 N20
71 Fuel
Theres a great writeup with pictures on dragstuff.com on how to read the plugs and the strap. If you want to take it to a science level. Definitely a little rich means a little more forgiveness for our stock pistons.
Old 09-01-2012, 07:55 PM
  #37
Old School Heavy
63 N20
71 Fuel
Wow bigger fuel jet than nitrous. I bet that bad boy has a bunch more in it!
Old 09-02-2012, 08:05 AM
  #38
jleews6's Avatar
With todays pistons the big thing that you have to worry about is knocking it. Make sure your timing is right and I would start with taking out 6 to 8* with 150 and work up from there. I would also make sure you have plenty of octane in it. I have always used Xylene and never had a problem.
Hyper pistons can put up with allot if your tune is right.
I helped tune a Mustang with a stock shortblock (hyper pistons) that made 240RWHP N/A and 470 with nitrous and it was together for almost 3 years before it split the block.
I also had a 302 that I ran two plates stacked because back in the 80s you could only buy a non adjustable 125 kit so I had two.
Never had a problem with that either.
Your car is going to fly with this kit on it. Just make sure your fuel supply can keep up and keep a close eye on the plugs.
Good luck and have fun.
Old 09-02-2012, 11:23 AM
  #39
Old School Heavy
I am going to test the fuel system by running a bypass hose from the supply side by the engine to the return line with a nitrous fuel jet as a restrictor and then make a pass or two to make sure it can maintain the fuel pressure.
Old 09-02-2012, 09:22 PM
  #40
jleews6's Avatar
LOL That's a great idea. I would have never thought of that.If it keeps up with it that way then you will have no problems with the nitrous.
Your going to have a low 10 second street car.
Quick Reply: Deliver Me From Temptation - N2O
