Deliver Me From Temptation - N2O
#143
Sorry to hear that man. I was a little disappointed with the workmanship on the Moser 12-bolt I put in my 99 TA. Welds weren't the best and the angles between the control arm mounts from side to side was inconsistent. Hopefully they'll make it right with you. That's why I went with Strange stuff for the Camaro.
#144
I had a pair of moser 12 bolt axles. New straight out of the box they were very sloppy on the spline fit. Could rotate the axle back and forth about 1/8" at the flange OD. For comparison the 40+ year old well worn stockers had less than 1/16". The ends of the spline machining were all over the place too. Sloppy workmanship.
I complained to moser about it and they said it would work fine and dont worry about it. The axles are still sitting in the corner unused. Moser=crap in my book.
#145
Well, they are sending me out another axle. Hopefully this one will be right.
Also, I found a new stainless steel replacement fuel tank for my car at Auto City Classics. Now I can weld in my custom stainless steel tank baffle/sump. This will allow me to run 16 or more gallons less fuel saving me 100 pounds.
#147
Anywho, hope they get you fixed up this time speed.
#148
#149
After doing a horrible job on my original tank I have been looking at a stainless one. I talked to the auto city guy at turkey rod run. $220 for a stainless a body tank sounds pretty awesome. Where are you getting a stainless sump? Are you going to fab your own? I considered making one myself. Are you mounting the sump back by the filler or down in the front? It seems like a trade off, down low or back.
#157
I think I will back off the initial hit to 60HP next pass though. It was a little too violent feeling and the car twisted a lot. It is hard too see in the grainy low resolution video, but it is going to need an anti-roll bar in the back if I am going to hit it that hard on the line.
Even with doubling the initial hit, the 60' was only 3 hundredths quicker. I think it was all lost in chassis deflection. I would have tried a softer hit, but I got the double whammy of the track manager coming after me for the 10.40s pass and then the rain came.
#158
What's the story with the track manager? Did he give you the "slow it down" speach or the "don't come back without a 6-point" speach? I'm guessing he didn't come over to offer his congratulations......
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#159
Looking back I guess you're right but to me, a 1.4-anything in the 60' is awesome for a mild mannered street car, and that 1.4 is what caught my eye. I consider my car mild mannered and I have more cam, converter and gear than you.....so I'm really impressed with the 1.48.
What's the story with the track manager? Did he give you the "slow it down" speach or the "don't come back without a 6-point" speach? I'm guessing he didn't come over to offer his congratulations......![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
But, he was laughing about how hard it ran.
