Need a carb asap!!
Need a carb asap!!
I got a LQ4 that I'm swapping into my caprice this weekend...for now its going to be a stock swap, next month im adding an EPS cam and mill my 317s along with a lil nitrous...today is last day i can order from Jegs and have carb by Friday....most run a 750 but which one? Please post part numbers for me...this is also a DD on weekends....$400 ish is my limit. Was looking at the Holleys for 279 but i dont know....THANKS
You can get an aluminum street avenger for just under your price limit
http://www.jegs.com/i/Holley/510/0-8...ductId=1118144
They also sell a pretty good selection of remanufactured carbs. I would look at one of those. The street avengers work a little better out of the box with LS motors than full up double pumpers.
Quick fuel is making a budget slayer series. They have better tuning features than the Holley, are cheaper and are still aluminum. Not sure if I have seen posts were anyone is running one, but the price sure is right.
http://www.jegs.com/p/Quick-Fuel/Qui...99058/10002/-1
Good call. I've actually been ordering more parts from Amazon myself. Catch it right and some items are considerably less than Jegs & Summit, free shipping too.
Dang I never looked at those Quick Fuel carbs.....my goals are to run 11s IF i can. Heads I will use are milled .030 317s and a EPS 234/246 cam...<<Which will get done next month but i need to get a carb now to drive the car and test out the engine while still STOCK..Plan on adding a at least a 100 shot on next month also. Gears I will use are my 3.42s in my 8.5..my converter is a 3000 revmax 9.5" in a built up TCI 700r4.
oh shoots....I've had my revmax for about 2 years now...and its held up pretting fine constantly racing it and also daily driving it...KNOCK ON WOOD!!! lol...when I get some more funds after I get my cam and heads done, i said I would add a bigger converter in it around 3600 or so..
As far as carb I was looking at...What are you guys thoughts on the Quick Fuel hotrod Series 780VS??
Those carbs have a lot of tunability built in.
QF must have come out with a couple of new lines in the last few months. About a year ago when I was looking to replace my Holley about the only thing they had for the street was the SS carbs.
WWWHHHHEEEWWWW......well good buy for me then....I just purchased this carb at 11:45 CT from Jegs....for $420.93 SHIPPED to my door OVERNIGHT...so it will be here tomorrow!...I priced match it with the link below and just took advantage of the overnight shipping since it would've came out to about the same price if I would've got it straight through Jegs no price match...I have to do some research on how to adjust these and learn more about them. So this is a 4150 baseplate carb then..Hopefully it does good on the 6.0 while when I called Quickfuel and Jegs, they both suggested no more than a 650cfm...I've never seen a 6.0 with less than a 750 on it so oh well..Thanks yall!!
http://autoplicity.com/products/1337...FcZrKgod3goA4Q
