Performer intake and nitrous?
Is anyone running a carbed performer intake with a nitrous plate setup?
Clearly the Victor Is the preferred part, but I am curious how the performer works with n2o. I searched for such a thread but came up dry. The split in the manifold looks like it might interfere with the spray bar setup. I have not yet contacted any manufacturers of nitrous kits for advice. I saw one setup where there was no plate, the spray bar was installed through a drilled victor down the center of the intake. Slick.
I am going to go the nitrous route once I work all the bugs out of my build, this was just on my mind planning for down the road. I currently have the performer manifold and bought it for the low end street grunt, but the overall picture is leaning toward a higher revving setup than I initially imagined. What do you fellas think about this?
Hi I have a pickup with a 6.0 and a Edelbrock performer and a Pro Systems 850 with a Zex plate,(there is no bar ) and so far have not had a problem. Used a 150 shot and ran a 7.15 in the 1/8th. Have made some suspension changes and will go to 200 then to 250 then to 300 shot. Ran a 11.27 on a 100 shot @ 119 mph.
Have not heard of any problem with this Zex plate. It is good to 300 shot. Of course I don't know if your bottom end is forged or not. Also I added a 1" spacer and with the nitrous plate it makes almost 2"s which adds some top end RPM. Good luck. Steve
Really a nice looking Chevelle.
If your interested, I might trade you my new Vic Jr for your performer RPM (if it's for cathedral intake ports). PM me if your interested.
Old School Heavy
Horsepower settings of 200 and 250 are for single plane manifolds only. In testing, we found that dual
plane manifolds have some distribution problems at these super high flowrates that could cause engine
damage. Please contact the Edelbrock Technical department with any questions you have concerning
jetting patterns and their effects on engine performance when using a dual plane manifold.
http://www.edelbrock.com/automotive_...7000/70053.pdf
Everything I have ever read says that a 150 shot is the ceiling for dual planes. Here is an excerpt from Edelbrock and the source document.
Interesting thread....I'm using the performer intake and wanted to run nitrous in the future as well. I would be interested to see the types of setups that work well with the dual plane, something like a 100 or 150 shot.
Thanks for the link SNY.
That was an interesting read. Basically tested and proved cylinder to cylinder distribution to not be a factor either way. I really wanted to maintain that low end. The dual plane is here to stay. Regardless, this motor won't see over 150 anyway most likely. You guys are awesome thanks again. This Chevelle will be driving by Christmas. That is a fact even if I need to take vacation time from work. The weeks have been zooming by and the car just sits there. I have been chipping away at it but all I need is about a week of dedicated time to roll out.
Hey no problem. I went with the dual for the same reasons. I want low end torque....lot's of it since that's where I will spend most of my street driving and it still performs at the top end...especially with a nice 150 shot for the drag strip
