Fox body LS, ZONES style
#222
Was not bad, just thought 4 PSI of fuel wasnt enough. Guess it is for the 1/8thg, but if i ran it out the back door in th 1/4 in third it would have started popping.
#225
Take the front center caps off. Use masking tape as your guide from the bottom and cut at LEAST one inch off the bottom. Tape them with a good clear packing tape and shove them back in the wheel. I think you may like it a little better and they won't trip anyone up as you drive by.
#234
Update, the anti roll bar came in Monday. Will have that and the 150 shot installed this week. See if I can test hit at the track Friday, if traction is there as I hope it will be, there will be blood. Got some folks to call out on my local forum and get some grudge racing done.
UPR makes some quality hardware, that's for damn sure. The welds are as nice as anything I have seen so these guys are surely making a product to stand by. Pre load is supposed to be set to 0. So, with my rear in the car I will have my brother make the adjustments after I get everything welded in.
