Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Winter updates
Old Feb 20, 2013 | 09:26 PM
Ls_Notch's Avatar
Default Winter updates
Finally got the car running somewhat good at the end of the season, 11.11 @ 124 through a tight ptc nitrous stall/glide with Ms4, stock heads/bottom end lq9 with a 650 holley. Thought about getting a plate kit and spraying on that setup but I figured I might as well go all out.
Got a good deal on a set of Prc Stage 3 243s, Had FTI spec me a all out stock bottom end nitrous cam, and had my Holley Ulta HP 850 tuned by CSU.
I am going to be using a nitrous express gemini 2 perimeter plate system.
Hopefully should be enough to run 9.50s, Im planning on working up to a 250 shot and see what she does!
Old Feb 21, 2013 | 10:44 AM
ZONES89RS's Avatar
In-Zane Moderator
Get it done! I hope you can make some passes as soon as possible.
Old Feb 21, 2013 | 06:39 PM
Ls_Notch's Avatar
Should be going soon, I have everything I need so this weekend I'm gonna get it all back together. Just if the weather cooperates I can get some motor passes in then start spraying.
Old Feb 22, 2013 | 01:15 AM
ZONES89RS's Avatar
In-Zane Moderator
Tryin to see if the dynatech headers for the 94-04 LS will work for my 80. If so I'll need to get everything together and start installing once my head gaskets come in. Motor is still sitting in the truck.
Old Feb 22, 2013 | 11:23 AM
The stunningman's Avatar
They won't. They have to be fox specific as the later ones get in the way of the steering shaft.
I have dynatechs 1 7/8" on my fairmont. I also had a set of BBK 351w 1 3/4 swap headers that I changed the flanges on that fit nice and would fit with the AJE or stock crossmember.
Old Feb 22, 2013 | 01:02 PM
ZONES89RS's Avatar
In-Zane Moderator
After some research, you are absolutely right. Looks close and may be able to make it work, but idk if I'm down for any extra work. Trying to find cheap painted 1 3/4 or larger sbf headers still. BBK is the cheapest I have seen new, 360$, still too much I think.
Old Feb 22, 2013 | 06:21 PM
Steve Sr.'s Avatar
Hey Travis, Sounds like you are really getting it together. You will really be close to your goal for sure.
With those heads and cam and carb retune you should be 10.60's or so NA. wow thats movin. Then with some nos your in the single digits. I will be getting my heads back in about 2 weeks.Also going to get a set of Harland Sharp roller rockers. With the heads done and the super vic, hoping to be around 10.30's on the 200 shot. Then we'll see about more nos.
Old Feb 22, 2013 | 06:30 PM
Dynatech Part number is 715-91410
Got a quote last july 575.00 from a sponsor here.
The BBK 1 3/4" headers are chrome plated and you should be able to find them used. The LS1 flanges are 50.00 all day long on ebay or whereever. A little time rounding the headers square ports to fit the flanges, Test fit them to make them fit perfectly and go to town with your mig. A hell of a lot easier than going the full custom route. I cut the ford ball flanges off and welded 3" collector rings to use regular collectors.
Not trying to hi-jack OP thread.
Old Feb 22, 2013 | 08:41 PM
Ls_Notch's Avatar
Ive got a set of the kooks 1 7/8- 3.5 and a aje k member and everything cleared great
Old Feb 22, 2013 | 11:11 PM
ZONES89RS's Avatar
In-Zane Moderator
Trying to go the cheapest route possible. Have a guy I can get the SN95 LS swap headers from for a good deal with a x pipe, but they are not going without a fight. Missed a few deals for some used bbk 1 3/4 headers already. Sucks. Kooks and dynatech are more than I want to spend, but if I sell some stuff I'll do it.
Old Feb 25, 2013 | 09:05 PM
Ls_Notch's Avatar
Should be back together and running this weekend, if the weather clears up i hope to make a couple n/a hits sunday. With the new cam and way better heads/carb Id think it should pick up. Hopefully get some 10.7s out of it with this setup.
Old Feb 26, 2013 | 06:17 AM
ZONES89RS's Avatar
In-Zane Moderator
Well hurry up!
Old Mar 6, 2013 | 07:45 PM
Ls_Notch's Avatar
ITS ALIVE!!! finally got it back together and running. Sounds really good, really responsive and has oil pressure so looks like I did something right, now time to make some passes and put the spray to it!
Old Mar 7, 2013 | 07:21 PM
Ls_Notch's Avatar
short idle vid with the new heads/cam
Old Mar 7, 2013 | 07:40 PM
ZONES89RS's Avatar
In-Zane Moderator
There you go!
Old Mar 7, 2013 | 08:03 PM
Ls_Notch's Avatar
Now ive just gotta get the tranny crossmember modded so I can get the mufflers on. Im going to run some spintech race mufflers, anyone run these?
Old Mar 14, 2013 | 09:43 PM
Ls_Notch's Avatar
a little idle vid after the new heads/cam
Old May 28, 2013 | 10:11 PM
Ls_Notch's Avatar
well its been a lil while but the car is running 10.80s-10.90s @ 126-127 pretty much every pass. Finally modded the stock tranny crossmember to clear the exhaust and got that on and the nitrous system is about done so if all goes well I should be able to make some hits on spray friday night. Im gonna start out with the 100 shot and see what it does, do you guys think 9.99s are a possibility? Its got a nitrous cam and stall so I think it shoud react good to it.
and the spintechs sound amazing I will have to get a vid up soon of them.
Old May 29, 2013 | 06:28 AM
ZONES89RS's Avatar
In-Zane Moderator
Weigh the car yet?
Old May 29, 2013 | 12:16 PM
Ls_Notch's Avatar
Haven't had a chance to yet, I've got a buddy that races dirt track and has a four corner scale he is gonna bring over sometime.
