Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Timing help...
Old Feb 24, 2013 | 06:41 PM
Doug G's Avatar
Default Timing help...
Hows this look for an initial ? Just loaded the MSD box up
2000 2-step ....But would like less
7000 max
-4* for N2O (maybe a 100 shot down the road?)
Old Feb 24, 2013 | 06:58 PM
ZONES89RS's Avatar
In-Zane Moderator
I set up 20* at zero, ramp all in by 2000 to max timing and take a two degree dip between 4k and 6k.
Old Feb 24, 2013 | 07:41 PM
89gmcs15's Avatar
I must have bad gas cuz I can only get to 29* at 3k before I get detonation up high.
Old Feb 25, 2013 | 03:45 PM
3pedals's Avatar
Doug, my engine liked to have the timing dip at torque peak. That was 5400 on mine, but should be similar on yours, maybe 5200. Dyno showed it liked 36* from idle to 3800, ramping slowly down to 32* at 5400 , then strait 32* through 8000.
Start your timing curve at 15* not 0, and bring in full timing a bit below idle rpm- like 500.
As for MAP timing, I can't remember what psia I had it dropping out, but I set up 15* from 0psia, to a point that was JUST higher(numercally) than cruise psia.
Drivability was good.
Barrett
EDIT: typo, I had 4800 where 3800 is now, big difference!
also this was for LS3 heads, flycut dish OEM pistons at 11:1 compression. this same curve worked nice at 9.5:1, with 2* added throughout curve
Old Feb 25, 2013 | 06:43 PM
Doug G's Avatar
OK....
2 more "tunes" loaded up in laptop to try once I get this thing running....MAP is just a guess until I get her fired up and a few runs around the block and I'll have the laptop with me to keep an eye on things and make an adjustment or three
Old Feb 25, 2013 | 08:45 PM
3pedals's Avatar
So easy compared to f'ing with distributors, you'll like it
Old Feb 25, 2013 | 09:57 PM
89gmcs15's Avatar
How much timing is everyone adding with a map sensor?
Old Feb 25, 2013 | 10:02 PM
3pedals's Avatar
Edited my post
Old Mar 3, 2013 | 09:04 AM
Doug G's Avatar
Mines not running just yet....dead battery and maybe bad gas ......but 12* as per top post as a starting point.
Old Mar 3, 2013 | 10:04 AM
speedtigger's Avatar
Old School Heavy
Which heads and which pistons and how much compression Doug?
Old Mar 3, 2013 | 10:14 AM
3pedals's Avatar
I added that info to my post for comparison
Old Mar 3, 2013 | 11:45 AM
Ls_Notch's Avatar
I run mine at 15 deg at zero and up to 36 at 700 and straight across, ive tried pulling some on top end but it seems to like that the best, that was with my old setup lq9. ms4, vic jr, kooks long tubes and race gas. Its awesome being able to adjust everything.
Old Mar 3, 2013 | 11:49 AM
Doug G's Avatar
Stock LS3 heads shaved .050, stock LQ4 pistons fly-cut, so about 10.3:1ish ?
Old Mar 3, 2013 | 01:08 PM
Old School Heavy
I personally would not go over 30 total until you have a chance to track or dyno tune the car. You don't gain much pushing in a few extra degrees of advance, so the risk to reward is just not there to flirt with detonation.
Old Mar 3, 2013 | 01:20 PM
Doug G's Avatar
This is why I asked/posted...still a lot of "old school" tendencies.
