Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Comp Thumpr cam
Old Mar 7, 2013 | 04:20 AM
Quick Ranger's Avatar
Default Comp Thumpr cam
Anyone here or know someone that has run these cams? Did a search, turned not much up. Mostly people saying they sucked, without proof to back it up. I found a car craft article that installed one in a 5.3, made 96hp, just with the cam. Granted, the duration was a bit high for my liking, but smaller ones are available. Thoughts?
Old Mar 7, 2013 | 08:27 AM
speedtigger's Avatar
Old School Heavy
LOL. Yep, that is how most of the forums outside of the carb forum are on tech. Shortly after that, somebody will tell you that you have to call the latest carb guru for a custom cam or your motor will not even run.
I think the reason there is not feedback on tech is that the type of person who would buy a Thumpr is not going to run out post his dyno numbers or track times to compete with their internet friends. Most Thumpr customers just want the sound and some performance and are not trying to outdo anyone.
The Thumpr series do not have the latest fastest ramps, nor are they trying to squeeze every last bit out of the curve. They are going for "the sound" and trying to be easy on the valve train. However, all of the people who say they don't work or won't work are pulling that out of their rear. I bet they will run pretty hard.
Old Mar 7, 2013 | 09:58 AM
EastTn6.0's Avatar
The best soulution for any cam questions I have had lately is to give Martin at Tick performance a call. He knows his stuff and you can get the right sound with a good power increase out of a custom cam. Im not sure of the numbers on the Thumper cam but he can have you one ground and shipped to your door before next weekend. Unless you are getting a smoking deal on the Thumper, I would give him a call. My .02
Old Mar 7, 2013 | 03:53 PM
ZONES89RS's Avatar
In-Zane Moderator
This numbers are goofy from a glance from those grinds. As stated by tigger, sound was the goal. Yet, the LS platform is a *****, you stick any cam in it and it will gain power. So, a increase in power will happen regardless. I would never run one. But, I would never go for just sound.
Old Mar 7, 2013 | 04:30 PM
Old School Heavy
Tech quote of the week.
Old Mar 7, 2013 | 04:36 PM
EastTn6.0's Avatar
This is hilarious. Also true.
Old Mar 7, 2013 | 06:58 PM
ZONES89RS's Avatar
In-Zane Moderator
Lol, glad I could please.
Old Mar 8, 2013 | 03:09 AM
See, i am one of those guys, i will never run on a dyno, i'm not trying to build an all out race motor here, just something that makes good power, fun on the street, occasional trip to the track.
Old Mar 8, 2013 | 03:18 AM
This cam made a 96hp gain on the dyno, over stock, on a stock 5.3. So what you are saying, other options in cams will provide an even greater gain? From what i saw, power was not that great below 3k, but a converter with a 3k stall sort of negates that.
I've look at the Eddy cams aswell, they show a decent power increase, but that is with their aftermarket heads, not the stockers.
Old Mar 8, 2013 | 04:53 AM
Doug G's Avatar
Don't believe everything on the internet....or in magazines.
Yes, those cam are just for sound....any power they made was a bonus.
Old Mar 8, 2013 | 06:30 AM
ZONES89RS's Avatar
In-Zane Moderator
Need to see that more than once in some magazine. Sounds good, but it is a magazine and I'm sure there were advertisements for that cam manufacturer in that rag.
Old Mar 9, 2013 | 05:01 AM
Well i guess i'll assume the numbers were false due to advertising. Only other options beside an edelbrock cam is to go custom(which the numbers they post are with their aftermarket heads). None of the sponsers on here offer a "carb" cam, so those would be rendered as useless. I'll get in contact with Martin at Tick, from searching he seems to be the man for custom cams.
Old Mar 9, 2013 | 06:02 AM
Pop N Wood's Avatar
All of the sponsors offer carb cams. Give them a call, they know what they are doing.
Lunati makes a series of off the shelf cams geared toward carbs. Huge lift numbers though.
http://www.lunatipower.com/Media/Doc...0LS%20Cams.pdf
GMPP makes a "stage 2" cam with a tight LSA. Don't know anyone who has run one of these, but interesting numbers
https://sdparts.com/details/gm-perfo...parts/88958722
Old Mar 9, 2013 | 08:04 AM
Old School Heavy
He is the "cam hero of the week" here on LS1Tech. (Not bagging on you Martin). Last year nearly every cam related post said "call Patrick G!" at least 3 times within the first page.
With that being said, Martin can help you pick custom specs very well. But, so cam most cam manufacturers.
Old Mar 9, 2013 | 02:33 PM
ZONES89RS's Avatar
In-Zane Moderator
There is also Geoff at EPS. But Martin is the one coming through just for us carb guys right now.
Old Mar 10, 2013 | 04:24 AM
Sales@Tick's Avatar
LMFAO!!!
If I had room in my signature to add that I would.
Old Mar 11, 2013 | 06:31 PM
3pedals's Avatar
A freind of mine ran the middle size thumper in his LQ4, no dyno or track times, but it runs HARD! It is in a c1500 with not enough stahl in the converter(2500) but it still works great.
Old Mar 11, 2013 | 07:48 PM
Now that is a response, not just guessing, actual results.
Old Mar 12, 2013 | 02:16 AM
ZONES89RS's Avatar
In-Zane Moderator
Well, don't know what results were there, but of it satisfies you. Like I mentioned, they are open to any mod, a random grind will respond to damn near and LS platform. And although not optimal it will be noticeable.
Old Mar 12, 2013 | 03:57 AM
I will keep my options open, i was looking at this cam from the article i saw. Doesn't hurt that i can buy it for under $300 either thru a person i know. Same with Wiseco, purchased 5.3 forged pistons thru a guy that works at Wiseco for $400.
