Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
intake bolts ???
Old May 4, 2013 | 09:53 PM
jaywill's Avatar
Default intake bolts ???
What do i torque them to ???
Old May 4, 2013 | 10:25 PM
The stunningman's Avatar
Stock intake calls for 89-100 INCH lbs. Using the rubber gaskets I would go by that. The paper style I would tighten them a little more.
Old May 4, 2013 | 11:11 PM
jaywill's Avatar
INCH lbs EXPLANE ???
Old May 4, 2013 | 11:58 PM
Zlow28's Avatar
righty tighty
Old May 5, 2013 | 02:34 AM
ZONES89RS's Avatar
In-Zane Moderator
I tighten them by hand till the intake is flush to the heads with the rubber o ring gaskets, then go a quarter turn more if it feels like it will go that far. Thats about the best way i can say. Otherwise, i tighten them to where i just "feel" comfortable.
Old May 5, 2013 | 03:54 AM
darren roar's Avatar
There are 2 different torque valves inch lbs and foot lbs. One is a larger torque wrench capable of more torque. They're are worth there weight in gold.
Old May 5, 2013 | 08:23 AM
jaywill's Avatar
Thank 4 the info !
Old May 5, 2013 | 02:56 PM
snook's Avatar
In case you are wondering, 100 inch lbs is 8.3333333 foot lbs. I always try to use one unless for some reason I cant. I always wondered why my old sbc intakes leaked until I started using a torque wrench,no more leaky after that, lol
Old May 5, 2013 | 05:22 PM
jaywill's Avatar
^^^ thanks !
Old May 5, 2013 | 07:54 PM
newschool72's Avatar
How many inches in a pound? 1 ft lb = 12 inch lbs. I hope that is right because that is how I convert the #s!! All my junk is torqued that way.
Old May 15, 2013 | 06:46 PM
dmracing's Avatar
Thats. what I do.
Old May 16, 2013 | 05:10 AM
Pop N Wood's Avatar
Yes, 12 inches to a foot. So multiply ft-lbs by 12 and divide inch-lbs by 12.
It's when you get a torque spec in newton meters that I need to break out the conversion table.
