New best for the ole mustang
well changed intake to open plenum had problems my carb not big enough,,, well traded for an e85 carb and its little to big for my bone stock motor,,, so decided to put the dual plane intake and carb back like it was last year,,, well finally went a 6.86 with a 1.46 60ft... so all the suspension stuff I did over the winter payed off.. best ive run at the track I ran at last night(last year) was a 7.00.. still this is a 110,000 mile bone stock motor....
Well just about got the zex nos kit hooked up,,,im hoping to spray 100 shot on it thur night,,,, ive got a get me a timing program made up for it,, just don't what to do use 93 or some 110 mixed with it or just straight 110...
mine is a ptc 9-1/2 inch,, well I leave about 2100 and it will flash about 35 to 3600,, I don't have the brake hooked up,,,i shift at 5700 and prob goes thu the 1/8 about 54 or so...
also im running 40 deg timing right now till 4000(that's right after the 60 ft) then pulling back to 38 deg through the run
.windmill is a hell of a drag racer...I've learned a lot from him, lucky to get to race with him. He gets his car to a science.
Zones, iirc you have a fairly large can in your car. If so and you shift it in the 6800-7000 range it needs to flash to around 5000-5200 to be optimal. PTC has helped me a bunch getting mine just right
Thanks streekknight,,, well looks like its still a go for tonight, no rain, I hope the bottle can stand 3 runs,, im going to try 100 shot with a little mix of 110 fuel,, then 150 shot,,,, them just might try the 200 with a new program late in the night,,,, we will see. I will post everything I did later tonight...
