How many cranking amps do you need!!! Msd 6010
So I just got my 408 in the car and ready to fire up...no dice. After searching all the threads I could find I figured out I had no spark..pulled All the plugs and then tried it. I had plenty of spark...put 3 plugs in, a battery charger, and tried it. No spark again. It appears that I have the box that requires 200 rpm of cranking before it will send a signal. How big a battery (cranking amps) do I need to make this mother hump?
Given the lack of other options I always hate hearing about the MSD boxes not firing with low cranking speeds. You might try contacting MSD and work with them. Sometimes they can reflash the box or will even send you a new one.
If you do need to upgrade starters I run an MSD starter. Price isn't too bad and that sucker cranks. Probably don't want to hear a suggestion to buy another MSD product to make up for another MSD product, but never the less.
I have had the exact same problem. twice. and read about others having this problem. don't worry, i have the answer for you. The problem is, your not cranking it fast enough to SYNCRONIZE the box with the motor. i tried brand new batteries wired in parallel and still no luck. i had spark with plug out of motor but not when they were in the motor. i tried sensors, which wasn't the problem. i called MSD (which has great customer service) and they sent me a new box and new harness. still had the problem. finally i gave in and did what a few on here talked about doing (which i didn't want to do) was put two batteries in series (24 volts) and try it. it fired up in 1 second of cranking. so i wired the ignition to be 12 volts and the starter to 24 volts. i was just scared about buring stuff up, but i figured if i only wire the starter to 24 volts then thats all that would burn up if it did. and it didn't. it literally took 1 sec of high speed 24 volt cranking and it fired up and syncronized. now 12v is all it takes to start it. i can almost gaurentee you this is your problem!! trust me i tried everything before resulting to 24 volts to the starter. Bottom Line, your not cranking fast enough.
if you need help wiring it up shoot me a message and ill help
I had the same issues your talking about...if you hook up a laptop to the MSD and crank you can verify that your crank sensor is getting a signal by verifying that you got the necessary 150 rpm crank...makes it easier than trying to run as splice into the crank sensor reference voltage that's for sure!
It's alive.....I took 2 short cables from the starter and a ground to the head hooked them to a tractor battery I had setting on the strut tower and ran the rest of the electrical from the 12 volt in the trunk. I put the battery booster on the battery up front....it cranked for 3 seconds and fired up. Like you said now the regular 12 volt in the trunk starts it just fine. Thanks for the input guys. I will try to post a thread with a link tomorrow...this new Tick Performance cam makes this thing sound like a pro mod!!!
