Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
loose bolt
Old Jun 28, 2013 | 10:11 PM
M7A1V's Avatar
Default loose bolt
did an oil change today and found a goldish colored 6mm X 20mm bolt in the oil pan...any idea what it was holding together?
I'm thinking one of the 4 bolts that holds the small pan in the bottom of the oil pan...
Frank
Old Jun 28, 2013 | 11:23 PM
ZONES89RS's Avatar
In-Zane Moderator
Pic of the bolt? Hope the pickup tube bolt didn't back out.
Old Jun 29, 2013 | 07:19 AM
M7A1V's Avatar
I'll get a pic later.
I was thinking the tube was held in with a stud and nut...
Old Jun 29, 2013 | 01:20 PM
ZONES89RS's Avatar
In-Zane Moderator
Nope, a small bolt.
Old Jun 29, 2013 | 09:36 PM
S10xGN's Avatar
Maybe a po dropped it, then replaced the bolt w/o fishing out the old one.
Old Jun 29, 2013 | 11:13 PM
wildcamaro's Avatar
Maybe a windbags tray bolt? Def need a pic
Old Jun 30, 2013 | 06:23 AM
M7A1V's Avatar
does look like the...oil pickup tube bolt...
Old Jun 30, 2013 | 06:50 AM
grimspyder's Avatar
Holy $###!
Id be losing my mind and pulling the pan OFF!!!!
Old Jun 30, 2013 | 08:37 AM
snook's Avatar
I bought one of these, makes me feel better anyway. If you do change it, get a new o-ring for the pick up, and make sure its not pinched http://www.brphotrods.com/mm5/mercha...ory_Code=CNV12
Old Jul 1, 2013 | 12:07 AM
wildcamaro's Avatar
Yea no doubt I would have ripped that pan off no matter what! If I was you Op I would clean those threads And use a drop of blue loctite for jnsurance
Old Jul 3, 2013 | 09:25 AM
CrashTestDummy's Avatar
You just gotta love autocorrect!!
Old Jul 3, 2013 | 10:50 AM
ZONES89RS's Avatar
In-Zane Moderator
The front cover removed will show the pickup tube to pump mounting point.
Old Jul 3, 2013 | 11:22 AM
velox65's Avatar
This^ do that first before you tear it apart. You may not need to but it doesn't look good
