opinions or best cam for ls2?
I have a 05 ls2 out of a gto it has a edelbrock performer rpm intake a 2" carb spacer and a edelbrock 650 cfm off road carb truck runs and works good just want more power..
I think im going to do new ported heads and cam or at least cam and new springs, pushrods, rockers..
what is a good cam for a stock bottom end ls2 to get most power but keep reliability. I don't mind a lot of lift its a off road race truck so I want it to be knarly thanks for your help
Old School Heavy
The most popular cam for milder LS builds that I have seen tend to range from 220 degrees of duration @ .050" to 228 degrees of duration @ .050" of duration. Any of those cams will work wonders on your combo. If you can find a good deal on a "220 cam" or a "224 cam" snap it up. It can have a lobe separation angle from 110 to 114 with that Performer RPM intake and it will run great.
However, if you go to a Victor Jr intake manifold down the road for more upper RPM power, then the cam will have to be more tailored for your application.
In addition, I did some testing with spacers on the Performer RPM intake and found no gains with any spacer.
Lastly, get yourself a 750 CFM mechanical secondary Holley based carburetor, you will pick up some free horsepower there.
In-Zane Moderator
Hey, for folks that are not looking for max power, they have their place. Who else has a off shelf grind for 300$? Lol. For folks looking for max power, those cams are not a option!
It is as we have 2 groups of LS swappers:
1: want it to run good but not be competitive in the racing world.
2: want it to get every oz of power possible.
That's pretty much how I have summed it up. Maybe I need a cut from edelbrock a groups 1 and martins group 2. Lol
ok well I would like to get or squeeze every bit of horsepower out of it I can with only 2-3k but I want to try and keep it as reliable as possible.. should I do heads and cam? should I do do cam and carburetor? and I actually drive the truck mostly at higher rpms
I am screaming that engine for long periods of time. right now its got a lot of torque and power in first and second but doesn't pull very well in third so I think gearing and some more hp and she should be a rocket
In-Zane Moderator
You simply do not have enough converter for max power, and as at as reliable, a smaller cam fits that category. We need to know exactly where you stand. I would not think you want to rev to the moon in a setup like that. Mid and early power is what I think you need.
im still learning this whole ls engine deal and especially carbureted..so that's why im asking you guys.. what do you mean I don't have enouph converter? you saying I need a higher stall speed like 3500? and as far as rev I have taken it to 7k a few times going from first to second but for the most part 4800-6200 is about the rpm range im always trying to be in cause that's where I feel she screams
